bios dump elitebook 840 g3
    Re: 840 g3 bios reconstruction
    Source : internet
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: 6050A2892401-MB-A01 BIOS please
      thanks this one ok
        Re: bios dump elitebook 840 g3
        Originally posted by Nurshad
        help me hp probook 840 g3 Caps Lock F12 Light blinking continuously
        if you need a bios, post the model of the motherboard and the original bios of the laptop.
          [QUOTE=imranromi;817274]Hi "imranromi" I am working on Hp EliteBook 840 G3 MB 6050A2892401-MB-A01. Working 100% fine but there is a BIOS Pasword, can you please help me remove this P/W. I have attached both the BIOS 64MB & 128MB original (with Password). Kindly clear & send back the file, I will appreciate. Thanks in advance
            [QUOTE=mferna14;1125661]
            Try the RCUnlocker
            https://www.badcaps.net/forum/showthread.php?t=103570 ->
            BIOS guides, methods, resources and tools
            https://www.badcaps.net/forum/showthread.php?t=103526 ->
            3. Password removal by laptop brand
            https://www.badcaps.net/forum/showpo...42&postcount=4
            3.6. HP
            BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required.
            You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539
            Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184
              [QUOTE=SMDFlea;1125668][QUOTE=mferna14;1125661]
              Thank you very much "SMDFlea" for informing me to use "RCUnlocker"... Never used it before but will surely try & inform you. Is this Unlocker menu driven & easy to understand what to do next?? I will read all the instuctions though.
                I have succeed to desolder the bios chip, how to read and write bios on this chip as it is different from what I have seen until now.
                I have ezp2019+ and ch341a programmers. What other tool do I need to be able to read and to write on this chip?
                Many thanks
                  Many thanks
                  https://www.youtube.com/watch?v=DWWigscuQDY
                  you can find more videos in this direction on the net..don't forget to make a copy of the original bios and check it with the HxD program to be ok ..
                    Many thanks for your help, my bios chip wson8 chip, I tried to use a sop8 to dip8 adapter to read the bios but the chip is always not detected.
                    Could you please advise.
                    PS: How to check bios dump is ok with HxD
                    Many thanks
                      Many thanks
                      Maybe your programmer doesn't support this chip.
                      Normally the structure of an Intel bios file will look like this.
                        Many thanks
                        Hi, please help, the bios chip is wson8. thanks
                          it is not detected because there is no perfect contact between the chip and the adapter ...
                          if you use CH341 A try one of these programs..after reading post the bios ...
                          https://www.badcaps.net/forum/showpo...6&postcount=10
                          https://www.badcaps.net/forum/showpo...04&postcount=7
                            hi i have a bios original but dont desplay can you help me please
                              Don't ask, if there's a broken bios that needs fixing, just upload it.
                                the attached bios files had a bios password on it.. anyone could clear it? i already tried some posted bios files but it all ended in no display problem...
                                thanks..
                                  thanks..
                                  Originally posted by SMDFlea View Post
                                  Try the RCUnlocker
                                  3.6. HP
                                    thanks
                                      hi need to unlock bios for hp elitebook 840
                                        https://www.badcaps.net/forum/showth...ht=rc+unlocker
                                          i have hp bios with password can you unlock..,thanks
