FPP55 LA-G07JP rev 1.0 bios dump
    Hi guys, I need help with this dump file for FPP55 LA G07JP rev 1.0, I understand it has two bios chips. w25x05clnig and 25q128fwsq does anyone have any available? thank you
    Re: FPP55 LA-G07JP rev 1.0 bios dump
    post the backup of the bios.
      I only have the backup of the 25q128fwsp, the second chip I can't read it. On the first, however, he gives me the failed verification
      https://drive.google.com/file/d/1aOh...ew?usp=sharing
        the bios posted is not ok..read this one again and post it again here, not on another site ... post the name and the complete model of the laptop ..
          this is another reading, but even here the verification has failed. The notebook is an HP 15-DB1063NL. Thanks for your help.
            bios extracted from the HP site update, the laptop has four bios variants, you write on the bios chip the 085EA1 chip that contains the DMI and KEYWIN information for your laptop.
            DMI + KEYWIN 61000-6203F
              Thank you very much. So should I write to the 25Q128FWSQ chip? the other chip 25X05CLNIG is useless?
                i tried to write bios 085ea1, but in the end it tells me that the content of the chip does not match the buffer
                  LA-G07JP REV2.0 Bios Dump Need
                  HP
                  FPP55 LA-G07JP REV 2.0 Bios Dump Need please help
                    Re: LA-G07JP REV2.0 Bios Dump Need
                    Use the forum search please...
                      [QUOTE=SMDFlea;1027062]Use the forum search please...[/QUO
                      I have used for rev 1.0 only needed rev2.0
                        Post the full laptop model number ,and your bios backup. Most new HP bios updates can be extracted by running the bios update.exe and selecting copy. You will lose DMI info though.
                          hp LA-G07JP REV 2.0 BİOS+EC NEED
                          hi hp la-g07jp rev 2.0 bio+ec need please help
                            Re: hp LA-G07JP REV 2.0 BİOS+EC NEED
                            See post #6. Check your bios using a hex editor to find your BID number. Peste has given the DMI area to copy from the old bios to the new one.
                            From post #12 "Most new HP bios updates can be extracted by running the bios update.exe and selecting copy. You will lose DMI info though."
                            EDIT: HxD hex editor has a tukish language version - https://mh-nexus.de/en/downloads.php?product=HxD20
                              Hp 15-ab1069au fpp55 la-g07jp ec bios need
                              I need EC BIOS for below model, I/O IC burnt so unable to take backup. Kindly send me
                              Product Model: HP 15-AB1069AU
                              MBD CODE : FPP55 LA-G07JP
                              Thank you
                                Re: Hp 15-ab1069au fpp55 la-g07jp ec bios need
                                Thank you
                                See the post above, post your bios BID
                                  Thank you
                                  post the original bios of the laptop (main) ..
                                    I've uploaded my backup file, thank you.
                                      in post # 6 you have everything you need ... use the bios with the 085EA bid and insert the DMI and KEYWIN information from your bios into the 085EA bios ... use the HxD program for this ... enter both bios in the program and copy- paste the interval from post # 6 ...
                                        I GOT IT AND MBD WORKING GOOD
                                        THANK YOU @PESTE AND @SMDFlea
