Apex LD 4088 backlight shut down
    I have this apex ld4088, the backlights will run for about 60 seconds and shut down, when they are working there is a slight buzz from inverter board. Power board is out putting the proper voltage. Standby 5v and the 24v to back light inverter board. 24v still present at plug on inverter when back lights quit. Thanks Michael
    Re: Apex LD 4088 backlight shut down
    One of the lamps or transformers on the inverter board may be failing. You need to look very carefully when the backlights are on to see if you have a dimmer line across the screen where a tube may be failing.
    Do you still have an image on the screen when backlights fail if you shine a light on the screen and look carefully.
      Will check that tonight, I do have a led tester. I will test each strip to see what the draw is. Thanks
        The set uses fluorescent tubes not leds and run at >1KVolts via the transformers on the inverter board
          https://www.badcaps.net/forum/attach...3&d=1601342388
          Are the Inverter board mounting screws missing?
          Inspect the Inverter transformers as suggested, also unplug the inverter board from the socket and inspect the inverter board fingers and the sockets.
            Ok I took the screws out to remove cover. Is there a way to check the output going to each tube? I looked that board over and didn't see anything that looked burnt. I don't have the screen off, is there anything else I can test before doing that? Thanks
              If I were make up a led conversion kit for it, is there any reason some shorter strips couldn’t be ran vertical instead of horizontal?
                Just checked it and still have image on screen when backlight quits.
                  Can you check the winding resistance of each of the inverter transformers and compare them to each other.
                  You said the set powers up briefly so are you able to see if there is a lighter band across the screen where one of the tubes may be failing?
                    these testers work well i have one myself
                    https://www.ebay.co.uk/itm/100-NEW-C...wAAOSwZ6tfRMou
                    this video maybe worth a watch shows how too test ccfl and also the transformers
                    https://www.youtube.com/watch?v=KCTVaW2XQ1o&t=1233s
                      Which terminal do I test across in this pic? https://www.dropbox.com/s/lkcm3859pj...D4D00.png?dl=0
                      1 and 3?
                        1 and 3?
                        It's better if you could attach any photo's to your post using Add Attachment. Dropbox wants you to sign in.
                        What's the inverter board part number?
                          There appears to be 4 solder points on each transformer.
                          If you label them 1 to 4 then test
                          Transformer 1
                          Pin 1 - 2
                          Pin 1 -3
                          Pin 1 - 4
                          then
                          Pin 2 - 3
                          Pin 2 - 4
                          then
                          Pin 3 - 4
                          Transformer 2
                          And note the resistance carefully for each test and for each transformer 1 to 10.
                          It would also be worth looking on the underside of the board to see if there is any sign of overheating. Board tends to brown.
                            Here is the pic, I saw one video that grounded the feedback wire to stop the shutting down. Do you know which one off the transformer is feedback?
                              Ok here we go.
                              1) 1-2 8.45 2) 1-2 8.27 3) 1-2 8.67 4) 1-2 7.9 5) 1-2 8.67
                              1-3 .03 1-3 .03 1-3 .03 1-3 .02 1-3 .03
                              1-4 8.3 1-4 7.09 1-4 7.8 1-4 8.62 1-4 8.3
                              2-3 8.4 2-3 8.38 2-3 8.01 2-3 8.5 2-3 8.3
                              2-4 .4 2-4 .4 2-4 .4 2-4 .4 2-4 .4
                              3-4 8.6 3-4 8.07 3-4 8.39 3-4 8.56 3-4 8.1
                              6) 1-2 8.67 7) 1-2 8.1 8) 1-2 7.8 9) 1-2 8.0 10) 1-2 7.9
                              1-3 .3 1-3 .3 1-3 .3 1-3 .3 1-3 .3
                              1-4 8.01 1-4 8.5 1-4 7.8 1-4 8.2 1-4 8.0
                              2-3 8.4 2-3 7.9 2-3 8.5 2-3 7.6 2-3 8.0
                              3-4 8.15 3-4 8.1 3-4 8.1 3-4 8.5 3-4 7.9
                                Well I had them in columns but they didn't stay that way.
                                  Can you recheck some of your readings and were they ohms, Kohms or Megohms?
                                  The transformers usually have a minimum of two windings on them so if one set of windings were labelled 1 and 2 and the other winding was 3 and 4 then you would expect a resistance reading of eg ohms for one set of windings and maybe 10's if not 100's of ohm for the second set of windings
                                    Across 1-2 readings are K ohm
                                    1-3 is ohm
                                    1-4 is mega ohms
                                    across 2-3 readings are mega ohm
                                    2-4 k ohms
                                    3-4 is mega ohm
                                      I'll assume that Pins 1 - 3 where it changes half way down is a typo.
                                      The ony odd reading is T4, Pins 1 -3 @ 0.02 which could be an error in the reading but worth rechecking.
                                      Can you also recheck Pins 2- 4 of each transformer with your meter set to ohms and post back the results.
                                        I appreciate all the guidance, I went ahead and ordered some led strips and will convert it over. I am going to start a new thread to discuss conversion. Thanks
