Canon Pixma G3111 no power
    In the first turn on with error (E04) referring to some printing head problem, when opening the cover I saw that something was blocking the printing head, I decided to disassemble to see if it had jammed and do a routine maintenance, when I put everything back in Your site did not turn on anymore, the source seems to be fine with 8.29v stable in the capacitors, I also read the same voltage here you can collaborate
    I think it could be a bios problem, you have more experience than you can point out
    Re: Canon Pixma G3111 no power
    Hello thanks for respoder I got another power source, with this it turns on and it has error p26 also note that the computer does not detect it, when trying to update with printer update.exe of the brand
    I am found that it is an epron problem since I also tried to correct the problem by doing factory reset through key combination and I did not get
