Yamaha A-520 HiFi amplifier
    Hi All,
    I have a Yamaha A-520 that has no sound output.
    I notice after power up the protection protection relay does not click in.
    I'd appreciate any pointers on where to start.
    Many thanks.
    Service Manual below:
    https://www.badcaps.net/forum/attach...1&d=1641841819
    Re: Yamaha A-520 HiFi amplifier
    first put a resistor and led across the relay coil to see if it's being powered but bad.
      Check the DC voltage on TPR0 or on the output coil L105 and L106. You likely have a bad output causing the protection circuit to activate to protect the speakers
        Probably dc on the output = blown transistor(s).
            I got back to the amp this morning and have a few developments to report:
            I have a series 120W tungstan lamp in series with the mains (240V) supply.
            On power up the amp draws lots of current to the point that R207 smokes (180Ω 1/4W)
            After a rapid disconection I desoldered the 4 main output transistors to test them (TR121,122,123,124) and all tested OK. (C3182x2 & A1265 x2)
            I also tested the two smaller transistors mounted between these pairs on the heatsink. (TR115/116 ) Unfortunatly I managed to break a leg off of one of these and now need to source a replacement 2SC2240. I'd appreciate suggestions for a substitute..
