Re: Sony xbr65x900c sound yes, no backlight or image.
Thanks VR69, that was buggin the hell out of me, I thought it tested like the rest before but I had to be wrong, guess I have to change it becuz it tested at 848.
It was, then I think I did too much research and went down the wrong path, thinking the backlights were at fault, tested each with tester all worked, was a pain, tiny connection pins, if you test them cover them with something, I just used a piece of notebook paper, they are blinding bright. I think my problem is on powerboard, waiting on the slow boat from china for parts.
Can't imagine that this board's zeners would be higher than most zeners, only 2 measure in spec, zd902 at 682 and zd907 at 710, unless someone has a similar working powerboard with these high readings, It has to be these guys are selling pure junk.
1N code at electronic parts world had others name code ( tomato ) you just bought Code not the deepest specification ,,,, how about the watt? did you know !!! so this is tomato can be used at any dishes. but who knows which taste at end will be.
