NEC Multisync LCD2190UXp display shutdown
    I have this NEC Multisync LCD monitor of 2010 with problem of 5 secs to black.
    If the brightness is reduced to 25 % the monitor works happily for 4-5 hours.
    When brightness is at 100% display will shutdown in 5-10 secs and front power indicator turns to flashing amber.When display is working this light is solid green and when shutdown light turns amber with 3 quick flashes >> off >> 3 quick flashes.
    All supply voltages are normal .The 12V supply to Inverter which is 11.8V at low brightness becomes 11.7V at full brightness which seems reasonable .
    5V is 4.94V with 0.04V variation.
    I have replaced all secondary capacitors even though physically they seem alright but No change.
    It seems this is a panel problem according to this thread below :
    http://hardforum.com/showthread.php?t=1694134
    I have not tried substituting CCFLs as there are 6 tubes with 2+1 connectors on each side IE only 1 standard 2pin CCFL connector and 1 non standard 4 pin CCFL connector on each side.
    Incidentally I have 4 such monitors with same problem but timing for shutdown is different.
    I was wondering if you guys have any other ideas or experience in this model.
    Samir
    Re: NEC Multisync LCD2190UXp display shutdown
    hi i have the same problem. did you able to solve it?
