Programmable and non-programmable SIO list
    Re: Programmable and non-programmable SIO list
    Originally posted by Ghamidi View Post
    list of EC, IO, KBC Programming and non Programming
    Hello, npce285pa0dx programable or not? thanx
      thanks
        hello,
        Is "ene I03730Q b1" programmable or not?
            Good info. Thanks
              Is the NPCD315HA0DX (or NPCD315HA0DX_A3 revision specifically) programmable?
              It has its own private EEPROM (HP Spitfire Rev A. board), and it runs HP SureStart. I want to remove that so I can flash coreboot without SureStart constantly replacing it.
                NPCE 586HA0MX programable or non-programmable unit hp circus-6050a2723701-mb-a02
                  npce885 model is not a programmable type.
                    hi
                    i need some help
                    i have hp folio 1040 ultrabook
                    it has smsc 1322-lzy
                    1322-lzy is getting hot
                    i need to replcae it
                    i need to know if i buy new 1322-lzy
                    should it need programing also or else
                    i just sold it and it will work
                    thx in advance ,
                      Originally posted by yop038 View Post
                      is IT8227E-256 progr ?
                      Is it programmable??
                        Tank very good
                          Hello what about NPCE68 ?
                            Hello
                            Im sure is ite it8517 IS programmable 128 KB.
                              Hello please is npce386pb0dx programmable? It is on the ideapad flex 5. Thank you
                                SMSC SCH5514E-NS Programmable or Non Programmable Chip
                                  Is it8655e programmable?
                                    ITE8655E-HXS
                                    ITE8655E-GXS
                                    Ite8655e hxs and gxs variants are interchangeable and do not appear to need programming, at least on Asus Prime B350m-a
                                    Last edited by Windows8RTMUser; 01-03-2023, 05:42 PM. Reason: better seo for ite8655e
                                      i need nm-c921 rev 1.0 programmable setting
                                        Is it programmable?
                                          Re: EC Nuvoton NPCX586GA0BX programming or not?
                                          Originally posted by SMDFlea View Post
                                          It has an external EC SPI rom ,page 28 in the schematic , U2803
                                          I was wonderding, as I'm new to this matter, if the Super I/O SMSC KBC1126-NU has been flagged as "non programmable", because the programming tools available as of now aren't able to program it or because it lacks of the programming memory by design.
                                          After reading the post I quoted I then looked at the schematic "HP ProBook 4540s S-Series Richie 13.3 UMA_DIS Muxless schematics.pdf" of the motherboard and found an external 8MB SPI flash connected to the Super I/O.
                                          I then make the deduction that in this case, same as the quoted case, the replacement of the KBC1126 IC doesn't require a programming task as the programming data are stored externally to the KBC1126 IC.
                                          Please correct me if I'wrong.
                                          Hal
