Lenovo ThinkPad T470 bios password decrypt
    Re: Lenovo ThinkPad T470 bios password decrypt
    CraterM you are a star !!!
    That worked a treat
    Thank you very much for your help
      this patch works to any t470? or just for the sent file?
        sorry but i need patch both chips? 25q80jv and 25q128fv?
          Upload your own file from 25Q128FV only.
            Hello friends, can someone help me with this bios t470, it is my first attempt to patch my bios but it does not give me an image, a somewhat special beep sounds but it does not give me an image, I have patched two b.option and files. len.translate I don't know what I did wrong ... can someone help me please.
              Try
                Thanks friend Crater, I will try and comment.
                  Originally posted by CraterM View Post
                  Try
                  working perfect I thank you very much but even on what I did wrong ..
                    Thinkpad T470 locked bios
                    I bought a used T470 that did not specifically mention the bios was locked, it only listed *199. My fault for not understanding what I was buying. I need help with removing the svp on the bios dump.
                    Thanks..
                      Re: Thinkpad T470 locked bios
                      Thanks..
                      Ok, try this comment how it goes
                        Thanks aldopc but I am having issues with the laptop not powering on. After getting the original dump I tried a clean bin for a T470 found in the forums and after flashing I had the power on issue. I flashed the original bin back but no luck. Any idea's for the power on issue? I have unplugged the internal battery and the cmos battery as well but that did not help. I will get the indicator light when the power cord is plugged in and the power button will flash a couple of times but that is all.
                        Thank you for the patched bin!
                          may some other hardware issue please check
                            Re: anyone can remove password from this dump t470
                            Hi there,
                            I have a supervisor password on my T470, I´d like to get removed. I extracted dump file with a CH341 reader and used AsProgramm 1.41.
                            May someone help, please?
                            Kind regards from Germany!
                              Originally posted by thinkmaro View Post
                              Hi there,
                              Thanks to KingBonecrusher for helping me out. SupervisorPassword is gone
                                Hello, I have a T470 and don't have the BIOS password, and need to access it to be able to boot my notebook (it isshowing me an error in the boot and forcing me to enter setup to fix it, but I can't enter and consequently cant boot).
                                I don't have knowledge of what tools (software and hardware) I need to access it and read/write the BIOS and how to remove this password as was mentioned before in this post.
                                Can you, or somebodyelse here, send me any tutorial or teach me how to identify the correct chip in my motherboard, read the information, dump it to be able to send here or to manually remove this passaword (or identify it in side the dump to be able to use to login)?
                                  If someone can help me by removing the supervisor password I'd be very pleased.
                                    bios
                                      Lenvo T470 BIOS remove computrace
                                      It´s posible to remove computrace from a T470 BIOS or its located in another place?
                                      Here its my bin just in case
                                      Thanks in advance!
                                        Re: Lenvo T470 BIOS remove computrace
                                        Thanks in advance!
                                        try..
                                          Lenovo Thinkpad T470 20JM Supervisor password
                                          Hi
                                          I have a 2017 Lenovo Thinkpad T470 20JM i5 6200U 2.3GHz with a bios/uefi supervisor password
                                          Could someone please assist with password removal
                                          I have read the bios/uefi eeprom with the CH341A usb programmer & Asprogrammer & it displays these in this order after the read:
                                          S25FL128K (SPANSION)
                                          W25Q128BV (WINDBOND)
                                          W25Q128FV (WINDBOND)
                                          I have uploaded a picture and the 3 files in a zip
