Please bios Toshiba Tecra C50-c
    Hi everyone
    Please, I need the bios for Toshiba Tecra C50-C celeron version
    I attach the .exe file downloaded from the official page but I don't know how to extract from it or if someone could explain me how to do it.
    I decompressed it with winrar and 7zip but it doesn't have a fd / bin file, only too many files.
    Please help.
    Thank you
    Re: Please bios Toshiba Tecra C50-c
    Originally posted by ruletero View Post
    Hi everyone
    Please help.
    Thank you
    see post # 4
    https://www.badcaps.net/forum/showthread.php?t=91357
      Ok, let me try. thank you!
        No luck
        I did all the steps and I get the bin file but the size is very lower, almost 6 MB. The original bios has 16 MB
        I attached the process. Did I do something wrong?
        thank you
          no luck
          i did all the steps and i get the bin file but the size is very lower, almost 6 mb. The original bios has 16 mb
          i attached the process. Did i do something wrong?
          Thank you
          you have to use fitc tool and decom your original dump and modify your bios region and rebuild it again by the help of fitc tool
            Hi
            Do you know or do you have a tutorial about that ? Is the first time that I hear that tool.
            Please
              No luck
              thank you
              No,its just that the extracted file is only a bios update,not the full one.
              Hi
              Please
              There`s a sticky thread at the top of the bios requests with an ME firmware cleaning tutorial . Post your bios backup and someone will fix it .
                Ok, this is my backup. Please someone could help me
                  try..
                    Originally posted by peste View Post
                    try..
                    No luck, with these bios the machine not turn on, with the original bios turn on but without video.
                      try..
                        Thanks peste but it isn´t working, same behavior, not turn on.
                        The laptop turns on (without video of course) without bios chip, also turns on with original bios.
                        In first case it has voltage in vgfx_core, in the second case it haven't.
                        The problem started when I changed a value in bios setup ( I don't remember what), after that, I saved and restarted the laptop and turn on without video.
                        This is the complete information for the laptop:
                        TECRA C50-C
                        Part: PS571U-05L02EST
                        Serial: 9G065875H
                        I have not found the correct bios in the web.
                        Thank you for your help.
                          Try this one.Your bios + DMI .
                            Re: pls Help me extracting Toshiba BIOS !!!!
                            Toshiba tecra c50-c a4097a need bios please
                              post as much data about the laptop as possible (see post # 12), and the original bios backup of the laptop.
                                i try this its working
                                  please unlock or dump this file for me
                                    Does anyone please extract the bin from this file or create dump?
                                      The password is stored in the SMSC MEC chip,it can`t be programmed as JTAG access is blocked. The only way to remove it is by challenge-response code or by using another chip from a donor board that has no pass.
                                      For information ... all these models are unlocked only through the response code:
                                      Portege (A30, A600, M100, M200, M300, M400, M700, M750, M780, R30-A, R100, R200, R400, R500, R600, R700, R830, R930, S100, Z830, Z930, Z10T-A, Z20T-B, Z30T-A/B/C, X20W-D, X30-D)
                                      Qosmio (F20, F30, F60, F750, G10, G20, G30, G40, G50)
                                      Satellite (M30, R10, R20, R630, R830, R840, R850, R930, Z930, U200, U920, Z30-A)
                                      Satellite Pro (A30-D, A40-D, A50, A120, M10, M30, R40-D, R50-B/C/D, R840, R850, R950, S200, S300, S300L, S500, U200)
                                      Tecra (A3X, A9, A10, A11, A40-D, A50, A50-D, C50-C, M1, M2, M3, M4, M5, M7, M9, M10, M11, R840, R850, R940, R950, S3, S4, S5, S10, S11, X40-D, W50- A, Z40T-A/B/C, Z50-A/B/C/D), WT310, Kira, Libretto (U100, W100)
                                      X30-E,Z50-E E...F series only service Toshiba can unlock.
                                      If you post your challenge code someone might give you the response code if you`re lucky.Otherwise you can find paid services if you google search for them.
                                        Thanks a lot dear
