Iiyama Prolite XB2374HDS
    Re: Iiyama Prolite XB2374HDS
    Originally posted by bernard51 View Post
    Hello.
    I know it's a long time...
    Have you solved you problem ?
    Perhaps, your problem is similar to the one describe here : https://www.badcaps.net/forum/showthread.php?t=39340
    I have this problrem...
    Hi!
    Yes and no; I mean.. after a lot of search on badcap forum (which doesn't include the link you posted, pretty strange that I haven't found it) and other website around the world, I contacted the service desk in Germany and I explained the issue by highlighting the fact that this is was at 99% caused by a faulty component (novatech chip) which dies after some usage as reported by a lot of users around the world and which regulates the digital ports DVI and HDMI (in fact on my monitor the VGA was working normally) and the monitor OS.
    Due to that "engineering issue" I tried to ask for a "no-cost" replacement for the logic board (I haven't the required equipment to program the novatech chip with the bios I found on a polish forum and to solder the newer on the logic board). Unfortunately we haven't found an agreement and I bought the entire logic board+shipment in italy from Germany.
    The shipment arrived almost immediately and I exchanged it the same day. My monitor is now working perfectly.
      Funny that my viewsonic vx2370 smh did the same thing only vga works now ,but then it is in burning-mode ,which ı cant make it out of this loop because buttons arent working cause I burned the soft key board ,yeah I am the most untalented fixer and patianceless.
        I use my ProLite B2475HDS only with the VGA input and I have the problem. I never used the other inputs.
        Can you please tell me, dedalo101, where you bought the board+shipment and what was its price ?
        Thanks.
          someone asked through google drive to have access to the photo:
          here the new links
          https://drive.google.com/drive/folde...LQ&usp=sharing
          The logic board
          https://drive.google.com/drive/folde...Gg&usp=sharing
          @ moderator
          could you please edit the first message and update the links?
            Originally posted by dedalo101 View Post
            @ moderator
            Done
              Someone have sent to me a request the access to another folder which contains photos of the main boards.
              Here the links to the main folder on my google drive.
              https://drive.google.com/drive/folde...6A&usp=sharing
