Thread Tools | Display Modes |
#1 |
City & State: Southampton
My Country: United Kingdom
I'm a: Knowledge Seeker
![]() Hi All,
I am trying to diagnose a faulty microwave oven and have checked the following components. Transformer – The primary and secondary windings have low resistances and no shorts to earth or between pri/sec. The high voltage capacitor (1.05uF/2200V) measures fine with no shorts to earth. The diode is not shorted or open circuit and when connected to a 9V battery drops 4V. The magnetron has a low resistance across the terminals and has no resistance to earth. I’ve put a clamp meter around one of the primary lines to the transformer and measured about 4A (240V) when the microwave is ‘on’. A cup of water in the microwave does not heat in any way. My gut feeling is that the magnetron is suspect but I’d appreciate any opinions on this. Many thanks. Last edited by Nevillet; 06-27-2022 at 09:31 AM.. |
#2 | |
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
![]() Quote:
Depending on the model of your microwave would determine weather or not replacing the
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() |
#3 |
City & State: Alberta
My Country: Canada
![]() Last to check is for open filament wiring at the connector/feed-through capacitors or for a bad connection there, or inside the can at the EMI chokes. Magnetron filament is low voltage, high current around 3.3VAC 11A for 36W, but caution it's at the (-ve) high voltage potential and not something to measure safely.
http://www.hokuto.co.jp/eng/products/magnetron/list.htm Measuring mains 4A is a bit misleading becuase there is the transformer's magnetizing current and the power factor needs to be taken into account. So it's not really 4A used, if you have a power meter check how many W it's using. |
#4 |
![]() The magnetron is a Toshiba 2M303H(EX) and I can't find a replacement in the UK.
How generic are magnetrons? The one I need is in this article: http://www.hokuto.co.jp/eng/products/magnetron/list.htm |
#5 |
My Country: USA
![]() Are you able to find the specifications for the one you have and match it up as close to what you have now
This aspect is going to very important as well to the one you have “ Type of Outline—> Direction of air flow and mounting patterns ” Which there several different air flow patterns and different mounting variations so you would have to match this as well Last edited by sam_sam_sam; 06-28-2022 at 10:28 AM.. |
#6 |
![]() I replaced the magnetron and it cured the problem.
Many thanks to all. |
#7 |
My Country: Canada
![]() That's good you got it fixed. Especially over counter ones are so expensive.
Where did you buy the replacement magnetron in the UK? |
#8 |
![]() The microwave was made by Electrolux and the magnetron was supplied by them as a spare item. The price was £70 including delivery.
Thread Tools | |
Display Modes | |
