Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 03-13-2012, 12:20 PM   #1
multimeter
City & State: devon
My Country: united kingdom
Line Voltage: 230v 50hz
I'm a: Hobbyist Tech
Default ezp2010 eeprom programmer
does anyone have this programmer and know how to use it?,i cant seem to get my head around it!,im messing around with a 24c--- eprom chip to try this machine out but totally lost on how to program it,i got a .bin file which has the firmware on it , but the file seems too big,any ideas?
multimeter is offline   Reply With Quote
Old 03-13-2012, 03:11 PM   #2
Rob Northen
City & State: Gentofte
My Country: Denmark
Line Voltage: 230VAC 50Hz
Default Re: ezp2010 eeprom programmer
Sure its a EPROM ? They usually start with 27Cxxxx
Rob Northen is offline   Reply With Quote
Old 03-13-2012, 04:11 PM   #3
multimeter
City & State: devon
Quote:
the actual one i need to rewrite is SPI Flash eprom 25X32VSIG,i was mucking around with the 24c etc trying to work out this programmer,trouble is i have a .bin file with the firmware on, but the programmer says that the file is too big,so i dont know what file to convert it to, or even how to convert it,and then how to put it into the programmer and get it onto the chip,this is a new avenue for me,so its all a bit vague,
Old 03-13-2012, 09:55 PM   #4
severach
City & State: Michigan
My Country: USA
Line Voltage: 120VAC 60Hz
24c,93c = Serial EEPROM, small, usually used to store configuration information that changes often
25x = Serial FLASH ROM, large, usually used to store ROM images that don't change often
W25X32 = 32M-bit = 4 MiB.
24C1024 = 1M-bit = 128KiB
24C02 = 2K-bit = 256 bytes
How big is the firmware image? I'm guessing 4MiB from the Serial FLASH part. The biggest Serial EEPROM I can find isn't nearly large enough and a Serial EEPROM won't sub for a Serial FLASH.
I'm guessing you're trying this with the most common 24C, the 24C02. This is a 2 kilobit chip containing 256 bytes.
Find the size of your parts and the size of your file. The size problem should become obvious.
severach is offline   Reply With Quote
Old 03-14-2012, 01:39 AM   #5
multimeter
City & State: devon
the file size is 4,096kb the chip is 25X32VSIG, will look up to find the data sheet in a while to find the size,are these chips available as "blanks"?,im in the uk,as i say the programming side is new to me!
Old 03-14-2012, 08:09 PM   #6
severach
My Country: USA
The only chips I can find with the VSIG suffix are by Winbond. To keep the chips straight the manufacturer's initials are often tacked on the front of the part number. In this case:
25X32VSIG -> W25X32VSIG
In my GQ-4X:
(*) Serial EEPROM -> Winbond -> W25X32VSIG
The W25X32VSIG looks like a 200mil SOIC-8W. Do you have the adapter? A SOIC-8 150mil adapter may look the same but won't fit.
Old 03-15-2012, 07:12 AM   #7
multimeter
City & State: devon
In my GQ-4X:
yes your right,its the only one i can find too by windbond, the actual manufacturer mark on my chip is, CSI,and its a soic-8 package,i dont have that adapter no,but i have 2 adapters where you can direct solder the chip to it to program it,i havent removed the chip from the board yet,im hoping to be able to erase the chip and re program it,i have the data sheet http://www.winbond.com.tw/NR/rdonlyr.../0/W25X32V.pdf ,but im not sure how to erase the chip,the data sheet sayes that the wp pin needs to be run high ,so im not quite sure
Old 03-15-2012, 08:07 AM   #8
popeye
Hi multimeter
I am also in the UK all the programer sockets and softwre and GQ-4X can be got hereplus plenty of info.
http://www.eeprom-programmers.co.uk/
popeye is offline   Reply With Quote
Old 03-16-2012, 09:33 PM   #9
severach
My Country: USA
Soldering a SOIC-8 chip may be easy but not so easy that I'd solder it to a board for programming.
If you were a chip or board designer then the write protect pin would be important. Your ezp2010 will be handling that. Look for the erase function in your ezp2010 software.
Old 01-10-2023, 02:25 AM   #10
Dr computer
City & State: ondo state, professional Engr
My Country: Nigeria
Line Voltage: 230vac
I'm a: Knowledge Seeker
Good morning ,I'm using ezp2010 programmer, its showing no programmer link connected
Dr computer is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
