Thread Tools | Display Modes |
#1 |
City & State: Kuala Lumpur
My Country: Malaysia
I'm a: Knowledge Seeker
![]() hello guys,
I am trying to control my homemade BGA rework with RS485 (USB) using a desktop PC, but a dialog box keep pop up saying communication error - cant establish connection between the BGA machine and the PC (refer pic). Some information: - using windows desktop PC - the software - PSoft Rework v 2.3.1 - the RS485 and the PC410 are properly connected i.e wired to the right pins - trying other IR6000 software but require a password for installation Appreciate your suggestion on how to rectify the problem. Thanks. |
#2 |
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
![]() first run a terminal program to make sure the usb interface and it's driver work.
99% of serial problems are down to the drivers or interface. |
#3 |
#4 |
City & State: ☻
My Country: Canada
![]() Did you install the driver for the usb to rs485 adaptor? If that is a CH340 adaptor I believe there is a program CH341SER.exe that will install the driver
#5 |
![]() i did install the compatible driver and it is recognized by the pc
#6 |
City & State: ☻
My Country: Canada
![]() What are your com port settings?, there is some information here: https://www.badcaps.net/forum/showth...t=60723&page=2
#7 | |
![]() Quote:
on the thread, i read it earlier but still i get the same result. |
#8 |
City & State: ☻
My Country: Canada
![]() I have read in the ACHI_IR6500 manual which looks like similar software, where the usb to serial needs to be set to com1, I see on another site that the psoft software can be configured to other com ports so make sure it is set to com7 like the serial adaptor
#9 | |
![]() Quote:
let me check where is this port 1 located in the motherboard |
#10 |
City & State: ☻
My Country: Canada
![]() I edited my post, I also found this site which has a bit of information https://www.antalife.com/2018/10/pro...plate-mod.html
#11 | |
![]() Quote:
but during my test earlier i did match the port from the com port and the psoft i.e i set port 7 for both psoft and pc |
#12 |
![]() is the controller using rs485?
i thought they where rs232 normally. |
#13 |
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
![]() From what i see that's precisely his mistake, imho.
The CH341 based is an USB to Serial converter, not an USB to RS232 converter! [@pronester see here how Serial and RS232 are different, already mentioned by @R_J] Therefore PC410 won't acknowledge connection. Either use the motherboard COM port or a truly USB to RS232 converter. |
#14 | |
![]() Quote:
#15 |
#16 |
City & State: ☻
My Country: Canada
![]() If the pc has an rs232 port, just use that instead of a usb to rs485 adaptor, It looks like the PC900 series (PC-410) will work with rs232, rs422 or rs485, One parameter that can be changed on the controller is the baud rate, so check what it is set to and match it.
acording to the ORDER CODE it could also be that the pc-410 is preconfigured for a certain communication configuration so check its complete part number Last edited by R_J; 10-13-2019 at 03:02 PM.. |
#17 | |
![]() Quote:
#18 |
Vinifera
City & State: Dilbeek
My Country: Belgium
Line Voltage: 230VAC
![]() Hi Pronester,
i have the same problem and my connection is via RS232 to USB ? have you found the solution ? Can you give me feedback thx |
#19 | |
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
![]() Quote:
![]() Perhaps we can help. We have been designing I/O adapters with 232/422/485 for the past 30+ years. |
#20 | |
City & State: London
My Country: UK
![]() Quote:
*After giving up on the the 2 laptops, and after many days have passed I was reaching for something on a shelf an old usbV1 hub fell in front of me and I picked it up and I said let me try to connect that to my laptop and to the achi pro* sc V1 and to my astonishment it worked on both latops.** I was very happy and started to ponder why is it working via the usb hubs but not directly via the latops usb ports and in my view very strange. I thought may be it is to do with drivers of the PC410 or win drivers. I cannot explain and I do not know the answer. I eventually found out that it does work via usbv2 hub too. The way I connect via the laptops, I ensure port settings in device manager match the port settings in psoft menu then first tab, configure com port. I connect cables to Achi pro first and then connect cable to laptop using an ordinary usb to rs232* serial converter to the USB v1 hub, from USB hun to pc, start laptop wait for it to boot to windows, I then switch on achi pro then open psoft and voila it works. When it connects the com port in psoft flashes green intermittently and on pc410, com flashes red intermittently. It can be temperamental too and If it does not work repeat the process switch off Achi and close psoft and start again and try in another port. It does work 99% of the time in my case. I would also check inside the Achi which wire is ground, rx and tx to Din rs232 port (mine) or usb port may be in Achi v2, v3 and v4. Mine was different to the schematics which I found on a utoob video. There is no logic in this, I am merely sharing my experience. |
Thread Tools | |
Display Modes | |
