Tektronix 422 losing intensity
    My Type 422 Tektronix scope intensity knob needs to be near or at max clockwise to be able to have a trace.
    Any suggestions on re-establishing full range intensity?
    Do I need a new CRT?
    Re: Tektronix 422 losing intensity
    I can't help you, but there are lots of Tek fans over at the eevblog.com forum. One person there, tekfan, as the name implies knows a lot about Tek scopes.
    --- begin sig file ---
    --- end sig file ---
      try cleaning the pot ,i had a freind had the same issue with an older scope,wouldnt show trace until it was fully clockwise,i cleaned it with contact cleaner and it worked fine after ,wasnt the same make as yours tho.
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        Hit it a couple times on the side!** It used to work with the old CRT TVs! lol!
        **Do NOT under any circumstances take my advise! If you decide to beat the hell out of your scope I (Peter9Do) take no responsibility for the outcome, which I for see not to be beneficial to the scope or yourself. I will also not take any responsibility for any personal injury you may do to your (but not limited to) hand, arm, head, foot, leg, knee in the process of dropping a dime on that sucka @$$ O-scope! Keep the proceedings as peaceful as possible and if you must go the rout of bitter rage please video it and post it on YouTube (Please share link on BadCaps forum) like the rest of us would! Thank you!
          Here is the service manual for the scope:
          Just click the link on the bottom of the page that says "get manual".
          Good luck!
          -Peter
            Your posted a link to the Tektronix 422 service manual that is for serial No. 1-19,999, do you have a link for serial No.'s 20,000 and above? The two manuals are not the same. Serial's 20K and above do not use Nuvistors.
              Usually the dimming is mostly irreversible and a new CRT is needed. About how many hours has it been used? (if the answer is "I don't know" assume tens of thousands of hours. Half life of regular CRTs are only around 15K hours!)
              With the service manual you should try the CRT calibration to see if it helps a little, make sure all the pots are good, and at least see if the voltages are good. There are some internal adjustments that may help, but once those are at their limits... new CRT time.
              There are some rejuvenators out there that may help the CRT for a few hundred hours but ultimately again a new CRT is needed.
              One question is whether focus is still good? then perhaps it could be a different problem.
