LG Dyrer Dley1201w
    LG Dyrer Dley1201w
    I dont know if i am posting this in the right area. But i have a LG dryer model Dley1201w. When i turn on the dryer you hear the relays kick on but drum does not spin. No error codes. I also checked the belt around the drum and belt is fine. Anyone have any ideas or that can guide me in the right direction.
    Re: LG Dyrer Dley1201w
    brushes, always start by checking brushes.
    nothing but trouble on every washing machine i'v had.
      http://www.appliancepartspros.com/pa...dley1201w.html
      https://www.tradebit.com/filedetail....-manual-repair
      https://applianceassistant.com/Appli...uals-Index.php
        Its not the washer its the dryer. You set your dryer sounds like it wants to kick on but it shuts down. The drum wont move.
          still uses a big motor.
          another common problem is bearings - if you can rotate the drum by hand they are o.k.
            Brushes? What? They use induction motors... At least all of them ive seen.....
            Follow the white rabbit.
              I looked up the motor for the OP's dryer. It is an induction motor, no brushes. The start/run centrifugal switch is probably broken and stuck in run mode. There isn't enough torque with the run windings to turn the drum from a stop.
              The motor is about $170 plus freight from a reputable supplier. Check appliancepartspros. They have outstanding warranty (1 year no questions asked and will accept returned parts, even electrical)
              Stupidity should be a crime, especially for drivers. I have NO patience for them.
                Do you see any cap near the motor if so check it
                9 PC LCD Monitor
                6 LCD Flat Screen TV
                1 Dell Mother Board
                15 Computer Power Supply
                All of these had CAPs POOF
                  I repair LG Appliances for a living and I suspect one of these: door switch, belt tension switch (on motor bracket) or a thermal fuse (on blower housing) the service manual is:
                  MFL62119959.pdf and you probably can google it and download it. Also check that both sides of the 240volts (1/2 of the supply could be out or a loose connection) to the center terminal.
