KSGER New Battery BMS Version Review
    This BMS board has promise it made like most BMS battery board I seen before but this one is made to use the power supply input jack and the power supply supply switch
    The first dispointment is the batteries that are used are no brand name batteries they claim 2 amp hour maybe this might be the case but I have not done a battery charge and discharge cycle yet so I can not comment on this yet so we will see if this claim is true or not
    But I going to use the Samsung battery out of a Kobalt battery from Lowe’s for $20.00
    The charger that comes with it says 2 amps @ 25.2 volts we will see what is inside this switching power supply and let you know if it worth a shit or not
    Here is a web link where to buy one go to product selection and you will see the kit with the a switching power supply
    http://s.aliexpress.com/fqYNf2A3
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: KSGER New Battery BMS Version Review
    did you see the new balancers on julien illet's vid?
    https://www.youtube.com/watch?v=Fb52fVaMeY8
      I was impressed with his demonstration of that board ( I have seen some of his YouTube videos before ) I am not very easily impressed
      Thanks for sharing this I was wondering if there was such a thing like this but I still think you would have to have a protection board for each cell for you to be safe working with these batteries
      9 PC LCD Monitor
      1 Dell Mother Board
        i think that's the idea, you can get 2 or 3 cell ones - maybe more.
        and they have that circuit for each cell/cell-pair
          Here are some pictures of the switching power supply board
          I have some comments about this charging board the first thing is that the temperature of the case does not any warmer than 102*F which I like
          The other thing is that the battery pack for soldering station battery voltage was at 24 volts on the soldering station controller which very close to my Radio Shack meter that I use all the time the charger brought the battery voltage to 25.3 volts and stop charging very good results
          What do you think about this charging board
          9 PC LCD Monitor
          1 Dell Mother Board
            It looks like six of a single cell charge controller/balancer circuits.
            At least the form-factor is better to fit inside an enclosure.
            I don't like the small chinese copy JST connector because they're crap and not rated for high currents or fatter wire. I would expect it to give problems.
              I would say the PSU has good bad and ugly.
              Good - heatsinks and lots of electronics, the board looks like a modified LED or laptop design.
              Missing common-mode choke for EMC and PTC for inrush current.
              Fail - primary to secondary spacings. The PCB board is a bad design for clearance, so ensure the DC output is earth-grounded for safety.
              I would say it's OK, medium quality.
                Thank you for your comments about this charger I will not leave plugged in when not charging batteries and will keep an eye on it when using it
                The component is a switching device and a power resistor and a diode of some type and a cap between the primary and secondary of the switching power supply board
                9 PC LCD Monitor
                1 Dell Mother Board
                  I know this as well and plan on doing something different but have not decided on what
                  One thought is to remove the two power supply wires from the connectors and leave the other ones
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    Most of them have some type of balancing circuit of some kind that why I made comment about the protection board for each cell but I would have to do some testing to how it would work
                    9 PC LCD Monitor
                    1 Dell Mother Board
                      I have bought one of these to try it out and see if it needs anything else for it work right when I have the answers I will post them here on this post
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        Things did not go well I was going to use my battery spot welders ( two of them different models but made by the same company ) but it would not fire the transformer again these Chinese Battery Spot Welder Controller are real CRAP you get about a year of use out of them
                        The transformer are very good I have not any real problem with them
                        I found some battery spot welder controllers for about $15.00 each which I going to use and when it does not want to work any more just replace with another controller
                        Because I enough welders with high output transformers that the controllers went bad
                        9 PC LCD Monitor
                        1 Dell Mother Board
                          check the big transistor - i have seen people talking about this before.
                            On one of them the adjustment does not work right you have to hold the set button to change the current and the cycle settings so on this one something is not quite right with the microcomputer on this one this one is going to get the new controller set up
                            The other one it might be the big transistor I have not had time to look at this one yet
                            9 PC LCD Monitor
                            1 Dell Mother Board
                              May I ask which battery spot welder that you buy?
                                Here is one of the battery spot welder
                                https://www.ebay.com/itm/797DH-Batte...53.m2749.l2649
                                I going to try and get this second version of the Ksger BMS board and do some testing and see if this one is any better in next few days
                                9 PC LCD Monitor
                                1 Dell Mother Board
                                  Well I have an update
                                  I hook up the BMS protection board and it charged batteries up evenly but the balancing resistors became very warm to the touch which is not unusual for this type of board
                                  But I have use it a few times to see how well it keeps the batteries balanced so we shall see what the results are later
                                  9 PC LCD Monitor
                                  1 Dell Mother Board
