Hi, looking for some help with a Honton HT-1212 I have bought if possible, I bought it off eBay as faulty due to the last owner messing with the settings so it will would no longer work (I have tried a Rex C100 from another machine of mine and it works with this controller), It has a Rex-C10 PID controller fitted but I am unable to find the correct manual for this controller, I can find a manual that says it is for the Rex C10 as well as the Rex C100 etc but the setting names of some of the settings are different the first 2 settings on my Rex-C10 are HP and LP, does anyone have the correct manual or the same machine with the Rex C-10 controller that could look at the settings and let me know what they should be. Thanks for any help you may be able to give.
Honton HT-1212 help
Re: Honton HT-1212 help
Does this help? or do you already have this, if is the REX-C10 series instruction manualAttached FilesLast edited by R_J; 01-06-2022, 12:58 PM.
Originally posted by R_J View PostDoes this help? or do you already have this, if is the REX-C10 series instruction manual
The settings I have on mine below with what the settings do that I have been able to work out,
The model is RKC REX-C10FK02-M*EN
Setting Range Explain
HP -999 to +999
LP -999 to +999
C -100 to +100 sensor calibration
OH -999 to +999
P 0 to 999 keeps going round if I keep button pressed
d 0 to 999
r 1 - 200
AR 0-1 auto tune
LOk 0-999 lockLast edited by livo; 01-07-2022, 03:42 AM.
So I managed to sort it, I played with the settings till I got it working but it was still over shoot the temp till I found a video on you tube which I had not seen before showing their settings on a Scotle ir 6000 which had the same as mine. So I copied them to my controller and it is now working a treat.
in case anyone needs them they are
HP 10
LP 10
C 0
OH 300
P10
I or backwards C 130
d 30
r 02
Ar 0
LoK 000
