Benchtop Power Supply Question
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8694
    Re: Benchtop Power Supply Question
    Well, the CMOS TLC555 can go down to 2v or so, if needed?
    • redwire
      • Dec 2010
      • 3902
      You need a reference voltage for the comparators, not sure what he's using for that. Hitachi 555's are pretty ooollldddd
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        #83
        I have almost finished a diagram's prototype for the laptops PSU project . So far , my choice went for a parallel series of LM338 , backed up by parallel diodes as illustrated in an image previously , while leaving a chance for additional ones , as necessary . Right now , I estimate LM338 power at 5A maximum , to stay on safe side , and for each another 5A , I'll add another one ..
        When the project is finished , although the delays and distractions were more than to count , It will be available only for some particular friends , and through PM's .
        In the meantime and for the people who liked my backups parts , my Sony Cam is back on line after some repairs , so I may re-post the previous images which were very bad , and yet , you know there are some size limits for uploads , so I'll resize them in PS as necessary .
        Here's a sample of my vintage capacitors .
          • 30977
          that picture looks like my dustbin after a repair
          parallel high current diodes doesnt work btw,
          the one with the lowest voltdrop takes more of the current - then fails leaving the remaining ones overloaded.
          then they fail.
          happens all the time in some cheap tv psu's that try to do it.
          also kills a lot of early Ryobo battery chargers
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            #85
            Come on stj; I'm in the middle of hundreds of projects , including a 30 km FM transmitter , and the picture's background initially should look vintage
            then they fail.
            I really doubt that when they're each rated 6A. and fyi , they'll be equipped with special heatsinks similar to old CRT monitors ...
            So you deserve another ...lol
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              #86
              @stj;
              That's how my dust bins look like ,
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                #87
                Originally posted by jiroy
                Come on stj; (...) and the picture's background initially should look vintage
                then they fail.
                In practice what @stj claims is TRUE! You'll watch this behavior when the overall current exceeds the maximum rate per diode (plus a unknown value).
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  #88
                  It's like pushing me to reveal more secrets I would prefer to keep it hidden!! Well fine megaraider ... How the overall current would know which one is the first when the special heatsink is making them symetric with high precision ? .
                  Yet , I do agree that if something is arranged chaotically , of course it will rise many different problems ..
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8694
                    The trick is to either go ahead and match them else current limit them, just like bjts.
                    • megaraider
                      • Jul 2015
                      • 307
                      • Portugal
                      #90
                      It's like pushing me to reveal more secrets I would prefer to keep it hidden!! (...) the special heatsink is making them symetric with high precision ? .
                      No secret ... IMO a great mistake.
                      The heatsink, no matter how 'special' it is, only works to keep the diodes under temperature limits, and if common to keep them all at about the same temperature.
                      Nothing else, sorry!
                      Yes!
                        • 30977
                        why not just use a 25A rectifier from an old pc psu?
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          #92
                          Yes!
                          Leave the how matter it is special , for me , and try to answer my question ... Though I won't tell you when you're right or wrong .
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            #93
                            It's because I'm leaving the always possibility to add more Diodes/LMs in case I want to put more laptops on the table . When I'll draw the circuit , I'll leave that possibility for lot of other parts too . So nothing against rectifiers basically other than that ..
                            I left the core calculations for the last touch for such reasons .
                            • megaraider
                              • Jul 2015
                              • 307
                              • Portugal
                              #94
                              Really No question to answer
                              Wishing you good luck exceeding individual max rated current using parallel diodes with you're special heatsink…
                              why not just use a 25a rectifier from an old pc psu?
                              it's because i'm leaving the always possibility to add more diodes/lms in case i want to put more laptops on the table.
                              Not a problem... add more rectifiers in parallel
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • Gjackson
                                Air-conditioning unit power supply failing to power up
                                by Gjackson
                                Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                01-08-2022, 09:24 AM
