does anyone have this programmer and know how to use it?,i cant seem to get my head around it!,im messing around with a 24c--- eprom chip to try this machine out but totally lost on how to program it,i got a .bin file which has the firmware on it , but the file seems too big,any ideas?
ezp2010 eeprom programmer
fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Tags: None -
Re: ezp2010 eeprom programmer
the actual one i need to rewrite is SPI Flash eprom 25X32VSIG,i was mucking around with the 24c etc trying to work out this programmer,trouble is i have a .bin file with the firmware on, but the programmer says that the file is too big,so i dont know what file to convert it to, or even how to convert it,and then how to put it into the programmer and get it onto the chip,this is a new avenue for me,so its all a bit vague,fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Comment
24c,93c = Serial EEPROM, small, usually used to store configuration information that changes often
25x = Serial FLASH ROM, large, usually used to store ROM images that don't change often
W25X32 = 32M-bit = 4 MiB.
24C1024 = 1M-bit = 128KiB
24C02 = 2K-bit = 256 bytes
How big is the firmware image? I'm guessing 4MiB from the Serial FLASH part. The biggest Serial EEPROM I can find isn't nearly large enough and a Serial EEPROM won't sub for a Serial FLASH.
I'm guessing you're trying this with the most common 24C, the 24C02. This is a 2 kilobit chip containing 256 bytes.
Find the size of your parts and the size of your file. The size problem should become obvious.Comment
the file size is 4,096kb the chip is 25X32VSIG, will look up to find the data sheet in a while to find the size,are these chips available as "blanks"?,im in the uk,as i say the programming side is new to me!fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
The only chips I can find with the VSIG suffix are by Winbond. To keep the chips straight the manufacturer's initials are often tacked on the front of the part number. In this case:
25X32VSIG -> W25X32VSIG
In my GQ-4X:
(*) Serial EEPROM -> Winbond -> W25X32VSIG
The W25X32VSIG looks like a 200mil SOIC-8W. Do you have the adapter? A SOIC-8 150mil adapter may look the same but won't fit.Comment
In my GQ-4X:
The W25X32VSIG looks like a 200mil SOIC-8W. Do you have the adapter? A SOIC-8 150mil adapter may look the same but won't fit.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
Hi multimeter
I am also in the UK all the programer sockets and softwre and GQ-4X can be got hereplus plenty of info.
http://www.eeprom-programmers.co.uk/Comment
Soldering a SOIC-8 chip may be easy but not so easy that I'd solder it to a board for programming.
If you were a chip or board designer then the write protect pin would be important. Your ezp2010 will be handling that. Look for the erase function in your ezp2010 software.Comment
Good morning ,I'm using ezp2010 programmer, its showing no programmer link connectedComment
by vinceroger69Hi has anyone got the latest software for the TL866CS MiniPro EPROM programmer version 03.2.86 is installed now i have tried the update site in the programmer software but it wont connect to their website i am running windows 10
Edit found this site programmer works now http://www.xgecu.com/EN/Index.html -
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
Channel: BIOS Requests ONLY!
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
Channel: Troubleshooting Audio Equipment
07-01-2024, 09:04 PM -
by BATZEB1981I want to manually reflash with a compatible programmer
The chip is in the picture
The car is in the title
Evga 2080ti
I have a dump rom thati want to try
I identified the eeprom chip as ls25wp080
It was said the CH341A Programmer
Should do the job but just want to make sure it's on the list of eeproms
Does anyone have the software or know if it might work after read
Or maybe the chip is wrong one I identified
Or maybe can... -
by Donny2derbyI keep seeing people in the Tv forum asking for eeprom programming and a lot of them seem to use a CH341a.
Is there a reason why this seems to be so popular? Or are there better and preferable alternatives?
Are there ones which a novice would be better off using?
Any suggestions welcome. - Loading...
- No more items.
