ESR meter upgrades
This is a sticky topic.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8694
    Re: ESR meter upgrades
    would expect digitally used transistors to be fairly easy to check for operation... it's either on or off, if it doesn't turn it on completely, it's bad....
      • 30971
      not so easy though when they are fired with short pulses and drive triac gates.
      (solenoid drivers)
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8694
        but still, you have a bank of solenoids, and one solenoid isn't working...well, something be a bad one on that circuit... (and then the TRIAC the AVRTransistortest pukes on...)
          • 30971
          but you dont have a wiring / loom schematic if the customer just brings the board.
          i dont want slot machines delivered just to fix a control pcb
          besides, you often spot parts that are "almost" failed so you can pre-emptivly prevent the board coming back a week later
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8694
            More fun with avr transistortester:
            Plugging in a 4N35 ... detects as a transistor.
            That's fine, now test 3 pins on a side at a time...
            one side shows up as a transistor. Good.
            other side shows up as a diode. Excellent.
            Too bad ...can't tell if it's working... or can it... I wonder what it would do if I connected the diode's cathode to the emitter, and connected those to pin 1. Connect the diode's anode to pin 2, and the collector of the transistor to pin 3... what would transistortester report this as...
              • 30971
              actually - you can test opto's with an adapter
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                I figured as much (need to lose one of the pins), but by doing this (shorting pins), isolation is lost
                So does it actually detect an artificially "broken" "optoisolator" in this way? Tell a triac or scr or bjt or photoresistor or photovoltaic or photodiode or other type of optoisolator?
                Incidentally, can it detect autotransformers? heh, probably shows up as a 3 pin short, but then again an inductor shows up as a 2 pin short.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8694
                  Fail. Autotransformers show up as two resistors...
                    • 30971
                    if you have the newer firmware for the opto-test it gives you the transfer value
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8694
                      hmm... thinking about it, trying to test an autotransformer (tapped transformer) might not be a great idea... but depends on how well the circuit is designed....
                        • 30971
                        shouldnt it show as an inductor?
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8694
                          It didn't for me... said two resistors, but that's besides the prob..l..em...
                          hmm. I think I figured out why it reported two resistors. aaah... circuit design.
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            #1093
                            Originally posted by eccerr0r
                            Just wondering... Ever since I got this AVRTransistorTester it's pretty much stayed in my "toy" pile and have yet to actually find a bad transistor or other device that I already knew of its status of good or bad from other tools or debugging techniques... Has anyone felt the same way?
                            Yes this sorta sounds like parade raining but just wonder how other people feel... do they use it a lot? Has it saved you effort? How so?
                            I use mine almost exclusively as an ESR meter / electrolytic cap tester (for testing caps out of circuit.) I know it probably sounds silly to pull caps out just to test them. At that point, many people will probably opt to just replace the cap(s) in question. But that's not always possible when testing the primary caps in a SMPS, which tend to be expensive. I do like to test them, though, because if bad, and if the PSU has APFC, chances are things will get destroyed on the primary at some point. On the other hand, if the cap(s) is good, I put it back in.
                            I also use my GM328 once in a while for measuring inductance on mostly larger inductors / non-SMPS transformers.
                            I rarely use if for anything else, though.
                            BTW seems that having big caps inserted on power up really slows down the power on auto self-cal it seems haha.
                            Yeah, I've noticed that too.
                            Not only that, but sometimes my GM328 will complain it hasn't been calibrated if I insert a relatively large cap (typically 4700 uF and up)... though not always. Drives me nuts when it does that, especially if it does it a few times in a row. It still works if I don't calibrate it, but the constant nagging message is annoying, so I end up calibrating it right away... until it does it again. I do wonder if the MCU memory is going bad, though. It never used to complain about the calibration probably for the first 3-4 years after I bought it and calibrated it (if not more.) Actually, it really only started doing it very often this past year.
                            Probably the inductance is too low to test??
                            I know at least my GM328 can't go lower than about 20 uH, IIRC. And sometimes even slightly higher than that will still report as a short-circuit / low value resistor, but no inductance (case in point: most output inductors on PSUs.) VRM inductors from motherboards are completely out of the question here, with most nowadays being under 1 uH. I actually performed a curious test: I gathered several such VRM inductors from scrap Xbox 360 motherboards and wired them in series. I don't know what their inductance is, but based on the circuit design's age, I'd guesstimate 2.2 uH or less. Wiring 4 of them in series did not give any inductance. I think even 6 of them didn't. And at 8x series, it reported 0.1 mH (10 uH) only half the time.
                            So yeah, at least the GM328 is not very useful for testing low-value inductors.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8694
                              I thought if I hook up any two wires to the tester, it will give me the expected reading; if I connect all three to the tester, it gives me two resistors...
                                • 30971
                                it works a lot better if you use my firmware instead of the factory one.
                                it's had the esr/inductor code re-written since the chinese compiled it.
                                also, a 20MHz crystal increases the accuracy.
                                (but you need to reprogram it to recognise the crystal)
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8694
                                  So what does your firmware report when you have an autotransformer attached?
                                  Two inductors in series doesn't quite work for an autotransformer...
                                    • 30971
                                    i dont have one.
                                    what the newer firmware does is take several averaged readings at different frequencies to get a better result.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8694
                                      Originally posted by stj
                                      i dont have one.
                                      If it's just that... it's still wrong
                                        • 30971
                                        the esr is more accurate
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8694
                                          esr of inductors is supposed to be frequency dependent, but telling inductors from resistors is different...
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
