Re: GE Microwave,no heat?
But Kaboom...did you ever see THIS::
An early 80's IIRC Kenmore MWV. Came in with a blwo n fuse. Replaced. closed door...no shorts on HV area.. Lit off...worked FINE.,..cooked well... UNTIL...I shut it OFF..or opened the door. THEN..there would be a loud "rumbling noise" from the HV tranny...and the fuse blew again.
at first...figured a weird door sw. problem or such.. SO I unhooked the primary of the HV tranny...and replaced the fuse...and opened and closed the door MANY times..NO problem.
Unlike most--if not ALL..modern MWV"s...this one used a TRIIAC..instead of a relay to break the primary line the the HV tranny. At FIRST...I thought "maybe it has a bad triac..which is SOMEHOW not "conducting right"..and somehow "chopping" the power to the tranny...which it would NOT like. BUt this did N OT help...powered up...worked great..until stopped or door opened AGAIN..SAME rumble from tranny and blown fuse.
I was not sure where to look next. THEN..I recalled a tv set which used a triac for control...and it ALSO did something similar. That turned out to be a bad OPTOCOUPLER.. which drove the gate of the triac. Somehow it was NOT conducting fully or such...and chopped the power to the VRT tranny (this was a Zenith CC-II set)...which then tripped the breaker after some seconds.
Turned out it was the SAME case HERE. The control board DID have an optocoupler--and evidently it WAS acting that way. After I located another opto (this was NOT a "modern opto" it was a LOT larger--as was the one in that tv set..) and installed it on the board ALL was GOOD..
I think I saw that..TWICE On an MWV and mabye 3 times on a tranny-powered tv set...
