LG Fridge Retrofit
    LG Fridge Retrofit
    http://ca.lge.com/en/ir/html/ABboard...eases_read.jsp
    A bad cap causes the condenser motor to fail, which will overheat the compressor and cook your fridge.
    I took a look at the general nature of appliance repairs at our store and noticed a good portion of control boards and such being fixed, a lot more than even a few yrs ago. So I've educated our tech on blown caps and he's looking for em now. Considering that a board can cost as much at $500 to replace, kinda makes one wonder.
    I'll post pics as we find em.
    Re: LG Fridge Retrofit
    i see a ton of appliance boards in for repair.many are not built to withstand the envirionment of say a washer or dishwasher.best bet is to avoid appliances with electronics.
    and ge stuff in general.
      Some of us have heard when the electronic control panel in a refrigerator fails, the refrigerator does not work, and therefore after some time, the food inside goes bad. Big problem!
      In such appliances, there should be a redundant controller, which switches on when the primary controller has failed. It should also indicate a service light as well, even though the redundant controller is still working.
      (The ECU in the VN Commodore we once owned failed twice - in many cases, an expensive and sometimes hard to find component!). Again, big problem!
