#241 |
City & State: aurora, CO
My Country: United States
![]() Thanks for the feedback. I’ll look at it deeper after work in a few days. I’ll gather some parts.
#242 | |
![]() Quote:
I received my order from Digikey -- the replacement capacitors. I ordered a few extra caps since I had to pay for shipping anyway ![]() I removed the burnt resistor and 220uf; along with the neighboring 470uf. Soldered in a new 470uf along with a new 68uf in the C3 position (I had to clean up the joint and contact from the burnt side). All soldered in and tested for continuity. I reassembled and it works perfectly!! Brighter that it ever has been and all modes work. YAY!!!!! ![]() ![]() A huge THANK YOU for all of the great information on this site and the awesome detailed responses from you - the experts. I am very grateful. I am so glad I took electronics classes in high school back in the late 80s. It made this task a simple one. I will keep an eye on it and I am hoping it lasts for another 20 years -- but I am sure we will replace it for a bigger and nicer one at some point. Safe holidays! |
#243 |
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
![]() I am glad you got it working again and for the time being it does not end up in the landfill or someplace like that for now
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() |
#244 |
![]() Here is a quick pic from this morning. Wife loves it. Just in time for holiday cooking!
![]() Thanks again! |
#245 |
City & State: Alberta
My Country: Canada
![]() That's great, I think some turkey gonna be cooking soon
![]() To summarize, fixing Jenn-Air oven display: Replace C3 68uF 35V (refurbished/newer boards upsized it to 220uF and added a resistor 27R 3W, for longer life... but they use cheap parts) Replace C4 470uF 35V It's a Digi-Key or Mouser parts order for under $20 incl. shipping, to fix an expensive wall-oven, keeping it out of landfill. |
#246 |
City & State: Brighton, U.K.
![]() I see that this specific subject has generated amazing interest over the years. Certainly, replacing electrolytics on the display pcb will bring back the Jenn Air (and others) display brightness.
However...these things are getting old by anyone's standards, so we have to be practical and realize that the VFD (the display tube itself) slowly ages and as it does, it becomes dimmer and dimmer. Nothing can be done about that. The second very common problem on these stoves is that various functions begin to start up and stop by themselves. Broiler fan starts to run all the time is the usual. I have examined the control pcb minutely and found no obvious part failures. A new control pcb fixes the ghost problems. No differences can be found between a bad board and a good board. Therefore I am 99% sure that the EEPROM on the original control boards also ages (from heat) and the software finally becomes corrupted. Since it is easy to burn an 8 pin EEPROM, I would recommend that someone do just that while your control board is still working. Then, the next problem worth mentioning is that the front panel membrane strip slowly absorbs grease, spray cleaners, etc. One or more of the functions stop working. The membrane can't be fixed and is no longer available. FYI there are several different part numbers for this membrane. The parts all look alike, but have subtle differences that can prevent them from mounting on your stove. The final award goes to the burners themselves. The glass-covered heating elements fail after some number of years. The pull-out heating units can't be disassembled without destroying them. It is sometimes possible to find plug in units with coil-style burners. All these parts are quite expensive. Pretty soon, the price of new stove starts looking attractive. Depends upon how creative you want to be. Good Luck, Longbow
Is it plugged in? |
#247 | |
City & State: Illinois
![]() Quote:
#248 |
City & State: St. Louis, MO
![]() Hi, the display on my JennAir JJW9827DDS double wall oven appears to be dim, so I was looking for ideas on which parts to replace. I found these images of the board from eBay.
#249 |
![]() The first picture it looks like there are two caps between the two displays and they look like are swollen at the tops of them it hard to tell from the pictures that you provided but that would be the best place to start if your caps look like them
#250 |
City & State: Denver, CO
![]() I also found this thread earlier this year. We have a Maytag MEW6630BAB. A friend was selling his house that had this oven in it. No one was buying the house. The potential buyers all said they wanted stainless appliances in the home. So, my friend went out and bought not as nice stainless appliances. He was going to have Best Buy take them away, but I swooped in and saved this double oven and a Maytag fridge (which now lives in my garage). The kitchen at my house didn't even have a cabinet for a double oven, but my wife and I were patient. We finally got some cash together to update our kitchen. New counter tops, removed old slide in stove and replaced with gas cook top, and a new cabinet for a double oven! I ran the electrical to the panel, installed the breaker in the panel. That oven was sitting in our garage for over 3 years at that point. It worked first try! Oven was doing great for about 6 months, then the display went very dark. Oven still works. Today, I finally found the motivation to crack open the front panel (much easier than I had feared, just 4 screws under the front panel). I found that the board is refurbished (confirmed by my friend who replaced the original with this). I've placed the order for the 4 caps. I'll get to mess around with my solder station, which is always fun!
#251 |
My Country: Canada
![]() Let us know what parts you bought... and don't put the new caps in backwards lol. (take pics).
Older beige boards have C3 68uF 35V and missing 27R 3W surge resistor - which gets added during a refurb. Newer boards increased C3 to 220uF. Is this list right: C3 220uF 35V C4,C5: 470uF 35VDC C7 2.2uF 50V C11 tantalum - people leave it alone Whirlpool 71001799 Oven Control Board Whirlpool 71001872 Oven Control Board I can't believe the ripoff pricing for these oven control boards. |
Thread Tools | |
Display Modes | |
