Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Appliances and other Household Electronic Stuff
Old 12-16-2014, 09:23 AM   #161
pbrabner
City & State: Hoover, AL
Default Re: Dim Clock LCD on Jenn-Air wall oven
Here is a photo of my display board. Model# JJW9530DDS. Which caps do I replace?
pbrabner is offline   Reply With Quote
Old 12-16-2014, 10:36 AM   #162
goontron
5000!
goontron's Avatar
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
All.
Follow the white rabbit.
goontron is offline   Reply With Quote
Old 12-16-2014, 02:27 PM   #163
pbrabner
I got the all part. What did the other comment mean?
Old 12-16-2014, 02:36 PM   #164
goontron
5000!
goontron's Avatar
My Country: US
both of these. if not the display itself could be bad.
Old 12-16-2014, 08:57 PM   #165
pbrabner
Now when I push Bake I am getting a message that says "Feature Not Available" I looked that up and it says that there is a fault that is keeping the cantroller from working. Any suggestions?
Old 12-16-2014, 09:09 PM   #166
goontron
5000!
goontron's Avatar
My Country: US
let me lookup thee reset procedure for the model.
Old 12-16-2014, 09:45 PM   #167
goontron
5000!
goontron's Avatar
My Country: US
Press and hold the BACK and ENTER pads simultaneously for five seconds.
Old 12-17-2014, 08:38 AM   #168
pbrabner
All that did was lock and unlock the door. When the "feature not available" message shows up there are two timers and timer #2 shows "1c2c" when the above message shows up.
Old 12-17-2014, 08:40 AM   #169
pbrabner
Also I when I had the panel off I touched the top end of two of the caps and they shocked me. That is not normal is it?
Old 12-17-2014, 10:15 AM   #170
goontron
5000!
goontron's Avatar
My Country: US
IIRC they are not isolated, so yes.
Old 12-17-2014, 10:19 AM   #171
goontron
5000!
goontron's Avatar
My Country: US
1c2c is a touchpad error... Strange. Can I get a pic of the front and back of the touchpad.
Old 12-30-2014, 04:38 PM   #172
large9
City & State: Santa Maria Ca.
My board just went out for the fourth time and the last board I put in has the resistor in series with the C3. I have three replaced bad boards plus a bad board in the stove and I ordered parts to cover all four boards. No one has mentioned a desolder pump so I guess I won't need one. I am repairing a 71003424 board.
large9 is offline   Reply With Quote
Old 01-04-2015, 09:55 AM   #173
large9
I ordered the parts for all the boards and now have the stove display is back. Two bad caps on the one board and resistors were used on two of the c3 slots for the other boards. I was surprised to see this but at least I will have a spare when the present board fails again.
Old 01-20-2015, 08:41 AM   #174
mbutle1
City & State: Shawnee, KS
All I can say is Thanks bluto and the members on this forum! I became a member just because of this topic. My Jenn-Aire oven's display over the last few weeks began dimming. I found this thread through a Google search. Read through it with great interest. This was my exact issue! I ordered the recommended parts from Digi-Key. After taking the oven face off. I replaced all the caps on the board. I have never replaced caps, ever. I was pretty confident after reading this post and watching several youtube videos about the subject. After putting my oven back together and turning the power back on to it. The display worked like brand new. The cost was under $10 and the time was one morning. Thank you for everything here!
mbutle1 is offline   Reply With Quote
Old 03-28-2015, 01:20 PM   #175
khs
City & State: Mansfield, Ontario
My Country: Canada
Thanks .... just repaired my Jenn-Air SVE47600WC using the info in this forum. I had plenty of experience with soldering components so it was a breeze. My solder sucker makes removal simple. Those without experience should keep in mind not to use too much heat as it will damage the traces on the board.
khs is offline   Reply With Quote
Old 09-12-2015, 05:49 PM   #176
Remidetroit
City & State: Virginia
Jenn-Air JDS9865BDP Range
Display became very dim about one week ago. It’s very dim as you must have lights out or hand over display to tell it even works. Reading forums I learned that C3 capacitor is likely the cause but my model is newer different. I planned to replace the capacitor anyway but was unable to find a 57u rated 250V locally. I went to a TV repair store to see if they stocked them and they put a quick tester on them (while still on circuit board) and they said “that’s not the problem”…. I had him put the same tester on C3, C6 and C7 which all tested good for what that’s worth. So now I don’t know if it’s a waste of time to still replace them or if this is a different problem. Advice?
Remidetroit is offline   Reply With Quote
Old 09-12-2015, 06:42 PM   #177
goontron
5000!
goontron's Avatar
My Country: US
did they test them with the board physically hot? if not, replace them. it could show up when the board warms.
Old 09-14-2015, 06:06 PM   #178
fzabkar
My Country: Australia
Line Voltage: 230VAC 50Hz
Check the capacitor on pins 2 and 3 of ST7.
fzabkar is offline   Reply With Quote
Old 09-14-2015, 09:18 PM   #179
clearchris
clearchris's Avatar
City & State: San Antonio
My Country: United States
Line Voltage: 120v 60hz / 240v 60hz
I'm a: Hardcore Geek
If the board is anywhere near heat, just replace all the caps. If they arent cooked yet, they will be soon. Caps are cheap.
I did this for my oven this year. Oven was only a few years old too.
clearchris is offline   Reply With Quote
Old 09-17-2015, 06:15 PM   #180
weisj
City & State: mass
My Country: usa
Just wanted to say thanks to Bluto and this site! Just successfully replaced the bad capacitor for my dimmed out oven clock. I have never soldered anything in my life or, sorry to say, even knew what a capacitor was but dammed if I was going to buy a new board without trying. Read the post, watched the video, bought all the equipment and voila!
Aint the internet great....
weisj is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
