Hi I was planning to buy a oscilloscope for laptop board repair do i really need to buy a 200mhz ? or the 100mhz is enough?
100hmz vs 200mhz oscilloscope
Re: 100hmz vs 200mhz oscilloscope
Originally posted by kalilinux25 View PostHi I was planning to buy a oscilloscope for laptop board repair do i really need to buy a 200mhz ? or the 100mhz is enough?
A power supply can probably be diagnosed with a 10 MHz 'scope. If you want to look at waveforms to/from a bank of DDR3, you'll likely be able to see "activity" with a slow 'scope but won't be able to verify Vhi and Vlo (as well as timing relationships between signals).
But, chances are, you wouldn't be able to recognize if something was subtly wrong (IME, most problems manifest "spectacularly").
The bandwidth of the 'scope essentially tells you what sort of an "RC" filter the 'scope represents. As frequencies of observed signals exceed the 'scope's bandwidth, they will be attenuated by this "filter" (as viewed by the 'scope). The more you (think you) need to see those fine details, the more bandwidth you want/need.
[Often, you can troubleshoot a product with a voltmeter and a logic probe]
Originally posted by CapLeaker View Posti've only got a 100mhz o'scope and its all i ever needed
For more than 4 signals, I drag out a LA for the same goal.
Things tend to work -- or not.
OTOH, when you're designing stuff, you want to be able to verify that everything you think SHOULD be happening is actually, in fact, happening. E.g., monitoring the configuration values jammed into the SDRAM to ensure it's operating with the correct refresh interval, bus timing, etc.
[LA is a real win, there!]
