Lenovo ID pin resistor values
    Hello, as you know, for Lenovo laptop, the AC adapters have an identification pin. They use a simple system with a resistor to ground from the ID pin.
    Here are some values for the resistors:
    65W adapter: 270 ohms
    45W adapter: 116.5 ohms (you can use 120)
    We had a T450s in with trouble recognizing adapter, due to poor quality power jack (not broken, just poor quality). Tried 3 adapters and it was hit and miss on all of them. I have disconnected the ID pin from the connector that plugs in the motherboard, and soldered a 270 ohm resistor from the connection of the ID pin to ground. Now any adapter plugged in is recognized as 65W, no problem charging the battery now.
    A working TV? How boring!
    Re: Lenovo ID pin resistor values
    http://www.thinkwiki.org/wiki/Power_Connector
    I've also made a little tester for laptop chargers. Still a 1 hour prototype but one day it will be made into a real tool, hopefully this year.
    https://www.badcaps.net/forum/showthread.php?t=70627
    Oh and for some reason, some 65W chargers have resistor for 90W charger for some reason. So it's not always accurate.
      so there is maybe a circuit that works out ohms law to find the wattage . or maybe 2 circuits .
        You mean on the laptop side? Probably just makes up a voltage divider and uses a comparator to see if the voltage is lower or higher than reference. But I wouldn't actually know, have not looked at motherboard schematic to see what's there exactly.
          Good Workaround boss......
            did anyone knows about the value of lenovo 230w charger?
            i have one with 4500ohms i dont know if its good or bad
              |45 W |120 Ω |
              |65 W |280 Ω |
              |90 W |550 Ω |
              |135W |1 kΩ. |
              |170W |1.9 kΩ|
              the resistance raises by wattage level. next wattage would have resistance little less than 4k
                You have the right value for your charger.
                https://www.thinkwiki.org/wiki/Power...230W_11.5_Amps
                  Originally posted by ktmmotocross View Post
                  |45 W |120 Ω |
                  |65 W |280 Ω |
                  |90 W |550 Ω |
                  |135W |1 kΩ. |
                  |170W |1.9 kΩ|
                  any charger above 170w have 4.5~5 kOhms resistance.
                    than u have 230W charger
                      Hi, my Thinkpad E560 can`t be powered up anymore . No LED. I changed the mainboard with another one apparently working before with all modules. Same problem. The charger is a 45W one, but the resistor has 178Ohm. I opened the connector and changed the resistor with 120Ohm. Same problem. Any Ideas? THX
                        I even tried to put 10 0hm on the output of the charger (ca 2A) The charger can supply also 20V by 2A and seems to be OK.
                          Apparently isn't "certainly". Borrow another genuine charger to test. My gut instinct says you have a motherboard problem or power jack problem and the charger is fine.
