HP ELITEBOOK X360 1040 G7 - "power-on authentication" problems.
    A customer dropped off a HP ELITEBOOK X360 1040 G7 with a "power-on authentication" problem.
    Customer says he didn't set this up. Neither password or fingerprint works.
    I have tried flashing:
    1) JBIOS1UH2
    with:
    a) RCUnlocker (by RethoricalCheese). Didn't do anything, beacause the chip is 32MB in size.
    b) HPUnlocker (by mazzif). Made a small change (changed: "00 00 00 00" to "FF FF FF FF".
    result: "power-on authentication" is still present.
    2) UEC3
    with:
    a) RCUnlocker (by RethoricalCheese). Makes a big change (see the attached screenshot).
    b) HPUnlocker (by mazzif). Made a small change. The change is similar to the change made to JBIOS1UH2. It changed 71x "FF"s to "00". Don't think I wrote thhis one back to the chip.
    There is another Winbond chip next to UEC3 designated UT9. The chip is a Winbond 25Q80DVIG. The 25Q80DVIG is a "3V 8M-BIT SERIAL FLASH MEMORY" chip. That means the chip is 1MB in size. Does anyone know what this chip is for? Is it worth it to dump it and run it through RCUnlocker/HPUnlocker?
    Does anyone have any other suggestions on how to remove "power-on authentication"?
    Thanks David
    Re: HP ELITEBOOK X360 1040 G7 - "power-on authentication" problems.
    Upload both bios dumps here.
    Become a Badcaps supporter
    Thanks to all supporters.​
      I have included before and after dumps (using RC Unlocker and HP Unlocker).
        Maybe you didn't make a good bios backup
          please backup again
            Both two files must be written to the corresponding chips simultaneously.
              Hello
              can anyone also unlock mine?
              Thank you
              BR
              Bojan
                Originally posted by bojc View Post
                Hello
                Thank you
                BR
                Bojan
                Please consider donation in support of the "Bios Requests" section of the forum.
                I've attached your unlocked dump:
                  it works
                  thank you very much
                    could you also unlock this one
                    thank you
                    BR
                    Bojan
                      thank you
                      BR
                      Bojan
                      There's no complications in your case now, only Admin password, no additional password protected user(s) or Computrace, so you can use RCUnlocker with your 16MB dump only, leave the 32MB chip as is. At first boot reset bios settings to factory default save/apply, then reset security settings and you're good to go.
                        thank you Sir
