Hp CQ62 SIO problem EC_USB_PWR_EN
    i have hp PM_A_HPC_S_MV_MB_V1 MOTHERBOARD.
    the 3.3/5v voltage regulator is working.
    i do not have the 5v on usb.
    following the schematic i notice that from ITE8502 ,EC_USB_PWR_EN goes to usb chip APL3510 EN pin directly which suppost to be 3.3v, i get 0.05v and then goes to 0 and then back to 0.05v.
    Can i give 3.3v from some other place instead of changing SIO ic!
    Re: Hp CQ62 SIO problem EC_USB_PWR_EN
    If the APL3510 is shorted why would you run 3.3V from somewhere else. Its an N channel mosfet, test it out of circuit
      Thanks for your reply,
      APL 3510 is not short. The voltage 3.3v is delivered from SIO pin 88 ec_udb_pwr_en to a resistor and then to pin 4 of alp3510.
      As I mentioned when having the probe of multimeter on pin 4 I see that shows 0.05v,then 0v and back to 0.05v.
      I tried resolve ite8502 but still the same result.
      The power on lamp is blinking and laptop does not turn on.
        measure pin on KBC.voltage and resistance to ground
          On keyboard connector pins 27,32 i get 0v.
          resistance to ground 5.43K but i do not get any shorts
            keyboard connector?
            KBC is SIO or EC
              Did you got schematics ! post it.
              what's the value of the resistor betwen pin 88 and pin 4 of alp3510 ! is it the same as the schematics !
