LENOVO G50 -70 power on No screen
    Hello from Greece
    I have problem with Lenovo g50 -70
    power on but i cannot see nothing in screen
    please check the picture .. is this OK ?
    Re: LENOVO G50 -70 power on No screen
    That one is PR306 and should have 200KΩ
    Anyway - it should power on and see something on display. what you have in picture is from battery charging. Works independently that part.
      i have 200ΚΩ
        Here is schematic.
          I put a ligth in screen and i see activite . but the backlight dont work and i dont see the lenovo logo.
          blinking a dim light
            Thank you for the schematic.
              as first flash bios. have many of it with bad bios program
                So you see picture but no backlight !..do you try on external display !
                can you take this measurement on JEDP1 : Pin 1/2 , Pin 21/22 , Pin 2 Q8
                  What means "Activite"?
                    I try with external display ... but not work
                    PIN 1 20.1V
                    PIN 2 20.1 V
                    PIN 21 3.4V
                    PIN 22 3.4V
                    pin 2 q8 ???
                      No need now for pin 2 of q8 since you got 3.4 at pin 21/22 , sorry to not ask for this before : pin 20/23 for 3vs ..if you got it than try another screen and /or another screen cable...if no backlight than try flashing bios .
                        I had a lot of lenovo with this type of problem. I just disconect lvds cable from display, reconnect back and everything is back to normal.
                          i try it but i have the same problem .
                          how to flash the bios with this problem ... ?
                            What about pin 20/30V !
                            To flash bios you must have/buy a mini programmer ( google it )
                              did you check the fuse near the lvds connector?
                                pin 20 0v
                                i try to find the R21
                                  R21 and C22 doesn't exist, if there is no short on pin 20 try to make a jumper from 3VS to this pin and see if there is a picture .
                                    take a look..
                                      3Vs appear after switshing power button ,this is your S0 satate.It supply many others IC's .
                                      why you don't have it on pin 20/23 !!
                                      can you take the measue of Q24 ( D/G/S) and see like Kiraro says if thers is a short on it !
                                        i make a jumper and i have this action from the screen ... no backligth and one horizontal line blink every 3 or 5 second ....
