Asus UX410U or UX310U
    Hello gays
    Do any one have this board view or schematics for this Asus UX410U
    or UX310 they have the same circuit i think.
    ASUS ux410u - Boardview and/or schematic
    I was not able to find anything for ASUS UX410U. Does anybody have the schematic and/or the boardview?
    I believe the board is similar to ASUS UX310 but not sure (asus said that just the screen is different).
    Thanks for any help
      Re: ASUS ux410u - Boardview and/or schematic
      hi. is your board layout like the attached? This is the boardview of the ux410.
        Hi mon2, is it possible to have the boardview file please?
          It really looks like this one. Not sure at this size but it seems to match perfectly.
          May you share the files?
          Alex
            Re: Asus UX410U or UX310U
            Merged your thread with an older one requesting the same .
              Asus UX310UV UX310UA UX310UQ Rev 2.0 Boardview
                Hi SMFFlea,
                Thank you very much.
                The boardview is correct for my board, it will really help.
                The repair guide is for UX410UQ. The pictures of the mainboard are different from mine.
                Thank you again!
                  You`re welcome. I removed the UX410UQ repair guide.
                    Ok, after looking more closely: my board is similar to the ASUS UX310UV : the general layout is the same (position of CPU, GPU, RAM, jack) but some components seems slightly different. It's better than nothing because some areas are really similar/same but if we can get the real one, that would be even better
                    Mon2, if you can share your file, it would be great to compare.
                      @SMDFlea, would you mind sharing the repair guide also please?
                        i posted it in a new thread - https://www.badcaps.net/forum/showthread.php?t=94392
                          Thank you!
                            Ok, did more check. I was wrong. The file UX310UV is really the right one for my UX410UV. I was not enough experimented but after some time, I've got used to the software and I'm now sure, the file is correct .
                              thank you broo
                                Repair guide
                                  Looking for an Asus UX310 UQR schematic, boardview or anything you have. Trying to fix the issue with random shorts on mosfets near CPU.
                                    Thanks Dear.
                                      Hi
                                      Thank you for this post, unfortunately I tried to open the fz with fritzing 1.0.1 (the only version that I could get hold of) and couldn't open it (after unzipping of course), I get "parse error, encountered incorrectly encoded content".
                                      Does it happen you to have another version , or know what fritzing I could use please ?
                                      With all my thanks
                                      Gar
                                        Originally posted by garouppa View Post
                                        Hi
                                        With all my thanks
                                        Gar
                                        This is quite a common mistake,you do not need fritzing. You can use BoardViewer from boardviewer.net or openboardview if the fz license key is added. https://www.badcaps.net/forum/showpo...16&postcount=7
