Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 11-29-2021, 05:31 PM   #1
thetonywarren
thetonywarren's Avatar
City & State: Green Bay, Wi.
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default TCL 75R615 has sound, no backlight
Have had this TV since June 2019, worked fine till today. Daughter was watching it and made a noise and went dark. I unplugged, left off then powered back on, no change. You can see the image with flashlight test, but has high pitched noise/whine and no backlight whatsoever......I also tried a factory reset with the reset button on the back. Any ideas where I should start troubleshooting? Im pretty good with soldering iron and multimeter, but I dont have any documentation on this TV so I dont know where to start.
thetonywarren is offline   Reply With Quote
Old 11-29-2021, 07:32 PM   #2
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Default Re: TCL 75R615 has sound, no backlight
I would start at power board. Sounds like shorted component causing the led driver to make noise. Need some pictures of boards.
__________________
dskall is offline   Reply With Quote
Old 12-05-2021, 05:14 PM   #3
thetonywarren
My Country: USA
So, I got some help yesterday to take the TV off the wall and got the back off to check out the boards....I did find a capacitor that was blown out,looks to be C312 a ceramic disc capacitor, very small and challenging to read, but was able to with a magnifying glass.....it seems to be a 220pf 1kv, I ordered some new ones from digi-key. A couple of questions, I dont notice with this type of capacitor that there is any polarity that needs to be observed? I have replaced numerous electrolytic caps and they have obvious polarity markings on the circuit board as well as the cap itself. Please see the attached pictures of the part number of the panel as well as some pictures of the internal boards, please offer up any help if you can....Thanks.
Old 12-05-2021, 05:32 PM   #4
dskall
dskall's Avatar
My Country: usa
No polarity on those. Does it measure as shorted?
Old 12-05-2021, 05:37 PM   #5
thetonywarren
My Country: USA
I just checked the component via continuity test and it is shorted.
Old 12-05-2021, 05:38 PM   #6
lotas
City & State: Sochi
My Country: russia
This is a high-voltage ceramic capacitor, they have no polarity, you can safely install it as you like.
lotas is online now   Reply With Quote
Old 12-05-2021, 05:41 PM   #7
dskall
dskall's Avatar
My Country: usa
You can probably remove it and see if everything powers up. Just read my disclaimer first.
Old 12-05-2021, 06:41 PM   #8
thetonywarren
My Country: USA
I think I'll wait till I receive the new component, before I power it back up....
Old 12-05-2021, 08:59 PM   #9
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
I would remove the disc cap and check it out of circuit, I would also check the mosfet QW301 & QW302. I usually replace these 1kv caps with a 2kv
R_J is offline   Reply With Quote
Old 12-05-2021, 09:18 PM   #10
thetonywarren
My Country: USA
When you say take the disc cap out of circuit, I'm assuming you mean the one that blew up and not another one near it or a different one? I did desolder it took it out of circuit and it tested shorted out ....I'll also check the two MOSFETs like you suggested......crap, I already bought the 1kv version instead of the 2kv like you said.....
Old 12-05-2021, 09:41 PM   #11
dskall
dskall's Avatar
My Country: usa
I'm surprised you had video.
Old 12-05-2021, 10:06 PM   #12
R_J
City & State: ☻
My Country: Canada
The 1k will be fine if that is what you ordered.
Old 12-05-2021, 10:09 PM   #13
R_J
City & State: ☻
My Country: Canada
Quote:
It seems to be the PFC circuit that has the shorted cap. The main board, t-con etc. likely operated and gave video but the led circuit needed the higher voltage and current to operate.
Old 12-05-2021, 10:27 PM   #14
dskall
dskall's Avatar
My Country: usa
Thanks again for the info. I get on here mostly to learn. Do you know what happened to budm? Looks to be about a year since he posted.
Old 12-06-2021, 08:41 AM   #15
thetonywarren
My Country: USA
QW301 & QW302, as far as testing them....can they be tested in circuit, or do they need to be removed to be tested, I just want to make sure I do it the correct way.....im sure I can google a testing procedure, but I want to do it the quickest, most correct way....
Please let me know and thanks again for everyones help with this, it is much appreciated.....
Old 12-06-2021, 09:07 AM   #16
lotas
City & State: Sochi
My Country: russia
You can check without soldering them, their legs should not be short-circuited with each other, this capacitor is parallel to the diodes.
Old 12-06-2021, 01:01 PM   #17
thetonywarren
My Country: USA
Ok, I'll test them later on this afternoon and post results on the mosfets....
Old 12-06-2021, 06:15 PM   #18
thetonywarren
My Country: USA
I tested both QW301 & QW302 in circuit and they are testing open across all legs.....I'm assuming per previous post that this means they are most likely good....
Old 12-06-2021, 07:21 PM   #19
dskall
dskall's Avatar
My Country: usa
Well they shouldn't test open. Probably not testing them right, but they almost always test shorted if bad.
Old 12-07-2021, 09:53 AM   #20
thetonywarren
My Country: USA
Ok, does anyone have a good source for how I should be testing these particular mosfets? Ive viewed a few videos on youtube, but just looking for suggestions.....
Thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
