Anyone know what the part in blue is and where I might get one? This 150 watt LED light stopped working after only about 6 months so I took it apart and visually all I can that may be bad is that part circled in red. It appears to be encased in resin but I can get to it and solder on a new one. Any help in identifying the part and where I might get a new one would be very appreciated.
150 Watt UV LED LIGHT
Re: 150 Watt UV LED LIGHT
Note it looks like Hot/Line (black) first connects to the MOV and then the bridge rectifier IC. It looks like Neutral (white) has the fuse in series? That would cause confusion.
Instead of working on it powered up, I would instead take some ohmmeter readings with power off. See if the mains cord has continuity to the bridge rectifier.
P.S. what are you doing with so much UV? Everybody glows nowadays lol.
I will check the BR in a bit, have family arriving for Christmas. As to what I need that much glow power for, lol I think you're going to love this! I built an 8 foot tall and 4 foot wide glow in the dark sasquatch out of resin and glow powder (see attached pic). I have video on my youtube channel called "Green Man Productions" that you can watch if you are so motivated. Let me know what ya think of my Sasquatch.
Originally posted by freakytiki4u View PostI just tested the Varister and there is 120 volts there on the left leg, nothing on the right leg.
There's an open-circuit somewhere on this LED board, 96 LED's and 20-24 IC's you would expect a bit of life. That 6A fuse would only pop if a short happened.
Soldering looks poor on one edge of all U16-20, somebody retouched the other side though. Not sure how the strings are configured or the IC part number.
I went on a fixup date with a woman that told me at night time she is visited by what looks to be glowing on your front lawn. The things they did to her!
Originally posted by redwire View PostP.S. what are you doing with so much UV? Everybody glows nowadays lol.9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Originally posted by freakytiki4u View PostLet me know what ya think of my Sasquatch.9 PC LCD Monitor
1 Dell Mother Board
