Inside a VL Holden Commodore ECU (made by Bosch), it had only two electrolytic capacitors. One is a 100uF 63V CE-HF series unit for the injector voltage reference; the other is a 330uF 25V GM series unit for a logic rail. Both of them were Matsushita 105C units, and are still good. All of the other polarized capacitors were tantalum units.
Should manufacturers avoid using electrolytic capacitors (and use tantalum units instead) as much as possible in their vehicle ECUs?
Also, is it safe to replace leaking electrolytic capacitors in vehicle ECUs with tantalum units?
