GTX 970 GPU crashes when loading drivers?
    Hey,
    I got a MSI GeForce GTX 970 which had a 2.5ohm short on the PCIE 6pin. I replaced one of the VCORE MOSFETs and the short was gone.
    The card boots up now. I got it booted into Windows, started downloading drivers (didn't install yet) and it just black screened - I assume Windows by that time had started loading its own GPU drivers onto mine.
    After that, everytime the PC would start booting Windows, I would get a a black screen.
    I went into Safe Mode (Worked fine) and installed the drivers. But I get the same issue went booting into normal Windows now. Any ideas on what is wrong?
    Re: GPU crashes when loading drivers?
    UPDATE:
    I managed to get it to boot into normal Windows, started up Heaven benchmark and it immediately went black screen.
    Not sure if I messed up the soldering on that 1 phase or if its an actual VRAM issue.
      Do you have artifacts?
        Re: GTX 970 GPU crashes when loading drivers?
        When the driver is installed, the gpu draws more current, so the mosfets are loaded more. One or more of the phases is not working try changing the other mosfets and make sure they all work.
          it can be bad ram. check with MATS. u will find bad chip/s. Bad ram is when u can boot to windows and work without driver normally. when driver is loaded or little load on hi res and ir crash
          OR
          one or more power phase is bad, u must check with scope before coil
            Update:
            Turns out that issue is only happening on HDMI. Card itself was running but HDMI would cut out. DVI is working fine. Very strange
              Originally posted by whc14765 View Post
              Update:
              Did you try the MATS test as ktmmotocross suggested?
                Hello everyone. Just another idea: did you check the capacitors? Check if they are ok, maybe when you stress the card in Heaven they get hot and their capacitance values drop below the minimum needed so the voltages can no longer be constant to power the core or the vrams. I hope I explained myself and that it helps. It doesn't explain why DVI works well, but you never know. I will be following this thread. Bye
                  u can remove 3 of them and nothing changes
