Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 01-24-2022, 04:59 AM   #1
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Gigabyte Rx560 - error 43
hello have this Rx560 that shows error 43. as mostly it is related to memory i reballed all chips and two memory tests show no error.
so whe can be problem when error 43?
ktmmotocross is offline   Reply With Quote
Old 01-24-2022, 11:44 AM   #2
dd10
City & State: PL
My Country: PL
Default Re: Gigabyte Rx560 - error 43
Try reprogramming the bios
dd10 is offline   Reply With Quote
Old 01-26-2022, 07:49 AM   #3
fab13
City & State: Arras
My Country: France
Hello to you
. I had the same problem with code 43 and maximum resolution 1024x1080 on my Rx 470. =(
And unable to install all the drivers. I had to erase the original program and reprogram another BIOS version. Try reprogramming the BIOS with AMDFlash I think. Ideally, save the original bios program on the chips and erase with a programmer found on Aliexpress and then install the correct compatible bios.
Start by installing a bios from oldest to newest and see if it crashes the system. If nothing does check the voltages on bios and PCI Express level I think. Hoping that the GPU is not faulty. Send a photo with CPU-Z.
fab13 is offline   Reply With Quote
Old 01-26-2022, 05:12 PM   #4
DynaxSC
City & State: Parcela/Mazowieckie
My Country: Poland
It could be that tserver does not detect a memory error, when the memory is only "somewhat" broken, so that it fails on higher frequencies only.
There is a way to let tserver test on higher frequencies -> You may try the hint from DrasticRepairs at the end of the thread:
https://www.badcaps.net/forum/showthread.php?t=101715
DynaxSC is offline   Reply With Quote
Old 01-29-2022, 01:02 PM   #5
ktmmotocross
Boardkiller
reball did not help so i found some used rams, replace it and bam. everything works
