Nope they are 5 dark purple Rubycon 3300 uF/6.3V capacitors...is it possible that my PWM is faulty ?
I would suspect a FET...
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
the caps with red line on top are failed on continuity test...
they're all beep very loud...
could it be the problem ?
NO.
You get beeping on continuity because those capacitors are connected in parallel with the CPU and your multimeter is reading the CPU continuity (which is almost always good enough to make any multimeter beep).
Educate yourself and do this test: measure the *resistance* of those capacitors on 2000 Ohm scale on your multimeter with the CPU in the board.
Then... remove CPU and repeat same test above.
In many cases, you will see different resistances, often getting open-circuit (or high resistance) when CPU is NOT on the motherboard. This is NORMAL. Likewise, it is typically NORMAL to get low resistance with the CPU in the motherboard.
If the motherboard beeps, usually that means all motherboard voltages are OK, CPU is up and running OK, and motherboard is able to read and execute BIOS... until it performs a Power-ON-self-test (POST) and finds that some piece of hardware isn't quite right. As R_J mentioned on the first page, one long and three short beeps likely indicates video error. Try a *PCI* video card, as he suggested.
Also, check the AGP slot for dirt or bad/shorting contacts. Or, problem could also be AGP signaling voltage being noisy. Typically, that is regulated by a MOSFET or linear regulator near the AGP slot. Output should read either 3.3V, 1.5V, or 0.8V, depending on what AGP video card you are using. Check what caps filter that.
Re: A7S333 1 long beep 3 short beep and shut down ?
I've found 1 8 pins SOP chip, which can not be read its label...could it the issue for this board ?
This chip was burned, that's why I can't read the label anymore...
It's located near modem connector...pin 2 3 6 7 are all connected on continuity test...
but I got no clue what chip is it....label completely gone....trying to see it now...
pin 2 3 6 7 are shorted to the ground as well, is it possible ? or it's just broken ?
I can't see the label and datasheet from it ....
You did take excellent pictures of it, though.
From what I can read on its label, I can make out a LM78L(?)05ACM.
So, I looked up a datasheet for a LM78L05 SOIC in Google, and got the following
Check it out - it's a standard 7805 5V linear regulator . As per the datasheet, pins 2, 3, 6, and 7 are all supposed to be ground... so that matches with what you measured..... So that's not the problem. That said, check what *resistance* you get on pin 8 (Vin) and pin 1 (Vout). Pins 4 and 5 are NC (i.e. Not Connected). Also, try measuring the voltage on pins 8 and 1 when you turn on the motherboard. I would guess that pin 8 is tied to the 12V PSU rail. You should see a stable 5V supply on pin 1 (Vout). If not, whatever that linear regulator is providing power to could be bad.
If this IC is near LAN connector like you said, perhaps the LAN chip went bad (often happens during a thunderstorm, since a lightning strike will create lots of EMI and RFI - enough to induce a substantial voltage on a long Ethernet cable sometimes).
That said, post a bigger picture of the overall of the board so we can see where this chip is located.
what's the normal voltage for Q1,Q3 and Q2,Q4....looks like they are 2 pairs for 5322
and from the schematic in datasheet, source suppose to be 12V but I can't get 12V on it...could it be another FET controlling it and it failed ?
But since it looks so burned, the next thing to do is find out what that regulator was powering and see if that is dead. Sometimes a LAN or on-board audio chip *can* make a motherboard not boot - at least not until they are removed.
So you have to find out what is powered by that LM78L05 regulator. To do that, check which chip gives you very good continuity numbers to pin 1 (5V output).
