LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    @fraymaker
    Check every connection between programmer and motherboard/chip.
      Bonjour je suis bloqué avec un L490 lenovo , j'ai essayé le patcher
      mais l'écran reste noir et il y a des beeps pouvez vous m'aider merci
        @drefo
        Most likely it will not work on 9th Generation ThinkPad models (Lx90, Tx90...), specially if this one have a 32MB bios. There are a few exceptions where ThinkPads having a 32MB bios can still be patched, but most likely all of them (32MB) have the "Self-healing bios" protection.
          @drefo
          The current working solution is more complicated depending on your level of experience, but you may first want to try to find out what's the EC/KBC (Embedded Controller/Keyboard Controller) part number, then look for a compatible EC/KBC programmer.
            Originally posted by drefo
            après avoir trouvé le controleur clavier que faut il faire? merci
            please in english here
              hi, for some reason i cant get this done, cant make it boot or show something after paching it (works with the original and blocked bios if i put back)
              any1 could do me the favor and pach this image?
              lenovo T440p
                Hello, I managed to patch the bios on my X1 Carbon 3rd Gen. When I plug in the battery and turn the laptop on it beeps 10 times but there is no image. Can anyone help? Thanks ahead.
                  i need lenovo t450p bios patch file
                    ;Hi,
                    I pray to be knocking at the right door.
                    i am stuck with my Lenovo X1 Yoga 3rd . i tried to use autopacher programme and generated the patched bios and flashed the eprom.
                    Since that my laptop does'nt start...
                    FYI , the eprom version is 25Q128JVSQ. i used Asprogrammer last version that gives me 3 options ( W25Q128BV, W25Q128FV, W25Q128JV-xQ ) i used the last one to save the bios.
                    Could you please look to my generated Bios and the it patched version and tell me if there is something wrong with ?
                    Coudl you patch the bios for me in order to be sure that there is no error with my patched version ?
                    Thank you very much for your help
                      I have carbon x1 gen 3 (20BS) and I cannot unlock the bios. I get 10 beeps and no display with patched bios. The problem seems to be the absence of a supervisor password. Seems like I cannot unlock bios without it. But I cannot set the supervisor password, the bios has a fingerprint protection and startup password. I cannot enter bios even in read-only mode(or don't know how to). Is there any workaround for this problem? Is there any other way to patch the bios?
                      P.S. I have attached the original unmodded bios. Thanks in advance.
                        lenovo x270 need patch help without hardware id . Tanks
                          X270 - https://www.badcaps.net/forum/showthread.php?t=81573 .Follow the instructions
                            Try ....
                              hi
                              my e595 backup
                              thanks
                                Originally posted by ak1_2004 View Post
                                hi
                                my e595 backup
                                thanks
                                Try ...
                                  Originally posted by Markus1741 View Post
                                  Try ...
                                  when use this , laptop dont bootup ! dont show anythings !
                                  thanks for anwer
                                    thanks for anwer
                                    @ak1_2004
                                    Inform more details of this model, a photo of the cover would be ideal
                                      Originally posted by onizzbox View Post
                                      @ak1_2004
                                      attached
                                        Try ....
                                        Thanks for the file but it didn't work the computer I don't turn on it just plays a sound like a song, turns on the keyboard lights and does not turn on the computer could you help me please?
