RT809F or GQ-4X with mx25l12845emi
    Hi guys,
    I wasn't sure where to post this as it is bios AND/OR equipment related. I have this 16pin IC that I need to program and a 16pin-clip-adapter. I clip the IC on the adapter (off-board) and connect the adapter to rt809f. The programmer cant detect the IC and if I choose it manually (or similar 25q128bvfg) that doesn't work either.
    Can you please tell me what am I doing wrong? Are these chips supported by these two programmers?
    Do I need a special adapter?
    Thank you!
    BR,
    George
    Re: RT809F or GQ-4X with mx25l12845emi
    MACRONIX MX25L12845E dates back from 2010 (at least) and it's a Serial Flash.
    Looked up RT809F supported ICs list (2018-12-18) and it's supported.
    MX25L12845E is known to be compatible with:
    W25Q128FVSIG, GD25Q128CSIG, EN25QH128A, W25Q128JVSQ, ...
    Try to select one of these manually (uncheck the Check ID option) and see if it works.
    If not consider MX25L12845E to be damaged.
      Ok I will try and report back. As long as there is no need for additional adapters other than the SOIC16 clip...
