Well, I see that I last posted on the subject of BIOS programmers Many years ago now. At that time I bought a Willem Programmer 5.0 which has the Parallel port and USB connectors. I never figured out how this was intended to work whether it was powered from the USB, the Parallel port on the card, or both. I never found a printer cable to make it work so that was a waste of $50.
There is now the TL866II programmer which has only the USB connectivity. Phil's Computer Lab on YouTube has a demonstration of the use of this new programmer.
Has anyone used on of these newer ones?
I note that there are very cheap programmers that can flash soldered on bios chips using a spring clip. These fit only 25-series BIOS chips which are physically smaller than the older removable chips. Apparently most modern motherboards use this type of BIOS chip. If you brick your motherboard the only way of recovering is to use one of these clamp-on flashers.
Interested to know your thoughts.
I have at least two boards with corrupted BIOSes.
My dead Abit UL8 is now giving a BIOS code 14 on my PCI Bios reader card.
The next code would be 16 which is Bad Checksum on the BIOS.
I have a P3TDLR Super-Micro board which also has a scrambled BIOS
