29.4v Chinese li-ion charger
    This charger arrived today for my ebike.
    I had to wire a new bms into the battery pack first as the original giant bms wouldn't work with a generic charger.
    Anyhow I plugged in the charger after connecting the battery and it charged fine.
    I noticed that once it finished charging the the status led on the charger stayed lit green even when the mains power was disconnected.
    I connected it back the mains and there was a loud bang. Charger has blown up
    I've contacted the seller on ebay, I just want your thoughts on the charger in general and wether it would be worth accepting a replacement if the seller offers
    Re: 29.4v Chinese li-ion charger
    This is the problem with switching power supply that are made in China there quality controls are hit and miss
    I do not like chargers that do what you described when you unplug it that the charge status indicator stays light like that
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Looks like the solder blobs caused a short, WTF!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      16 GB AData XPG Spectrix D41
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        Man! what kind of fuse did they installed in F1 location?
          get your money back and feel lucky your house didn't burn down .
            "Improved" version of Apple fuse
              apple fuses are the best, they last decades.
              not like those cheap chinese shit that burn out as soon as you reach the rated current!
              /sarc
                i see what happened,
                the board is designed for a box-fuse and they fitted a tiny glass fuse.
                combined with a shorted bridge rectifier (happens),
                the fuse couldnt break the circuit fast enough and it arc'd under the board.
                  sigh... more chinese noob phails yet again...
                    I would get the money back and buy something better.
                    BTW, can see the enclosure so we can see the make and model and the markings?
                      I second this
                      9 PC LCD Monitor
                      1 Dell Mother Board
