Ps3 fat Cechk04 no power
    Re: Ps3 fat Cechk04 no power
    the fat's have touch-sensors, slims have cheap tactile buttons.
    Yup, we are on the same page then with the case design.
    I'm still not convinced about the PSUs, though.
    Perhaps post PSU model numbers to be clear?
      i will take a photo or 2 on saturday - it's still in bits waiting for a shell (dont ask!) so no problem doing that.
        Originally posted by Admirality View Post
        Hi all my ps3 when plugged in just flashes green the ned and afterwards no led at all,pls help,it will be greatly appreciated
        The schematic is attached.
          Ok stj i tested 5vsb and that is ok,now i just need to test for 12v to check if the psu is ok but it is taking a while as i am working a day job and tired at night and want to be alert when working with electronics
            Hi ricardoito thanks for diagrams but my psu,a Delta EADP 260AP A has only 3 pins,pson gnd and 5vsb
              I am sure they work the same way stj,3 pin psu's i mean
                [/ATTACH]I have tested the psu and 5vsb and 12v is there so the problem lies on the main board and found this,are they capacitors?
                  yes, ceramic caps
                  if just desoldering that fixes your fault then your very lucky.
                    Thanks stj,but where do i find the value of the cap
                      meter a good one.
                      it will probably be o.k. with one missing anyway - so just removing it is o.k. for testing
                        it is:
                        22uf 16v X7R dielectric in a 3225 size
                          stj much appreciated for all your help
                            i removed the cap now and tested it,it comes on and has the green led and blue led and gives 3 beeps,does that sound right stj
                              cant remember, it does different things if for example the settings are corrupt because you took the battery out for a while.
                              hook up a hdmi cable and check the screen - any usb joypad can be used
                                Ok are the other caps around the bad one also 220microfarad
                                  i just dont see the caps position on the schematic of side B board
                                    The blue lead is indicating that there is disk in the tray ... if there is not the disk in the tray there might me an issue with the CXR chip , or is detecting some kind of error... So did the ps3 come on? , does it turn off again?
                                      you can just visually check the area around that cxr chip and under it on the other side of board , if your disk drive is not working...
                                        Thanks sigmeyer,the ps3 after removing the bad cap comes on,the fan turns on then afterward it flashes red led,that is without the bad cap in
                                          Yesterday when i pressed eject it made a clicking sound,i am sure the owner of it told me that there is a disc still in the disc drive
