Solar led chipset
    Solar led chipset
    Hi All,
    Anyone know what ic(U1) is that? Phisical p/n :9hHDMH
    Or any equivalent ic that i can use?
    Re: Solar led chipset
    It does not seem to be a good part number
    Is there anything else on this ic chip
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Hi SAM,
      Only that model no. can be found on physical
        That number does not look right, it may be custom IC. Did you try cleaning the top of the IC to see if you can see anything else on top of the IC? Any way, what is the board not doing?
          The "LED light cannot power on due to this IC faulty and i can't find any part number on top of the IC.
            I see an IR receiver module, so the IC must be a microcontroller with custom firmware.
