iMac 27-Inch "Core i7" 3.4 (Mid-2011):
First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
Searched all over for one!
All voltages to the Inverter are correct:
(12v in, 3.3v Enable and PWM Approx 3.0v).
Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct at 42v. Before repairing the Inverter I tested the LEDs one by one in the display with a multimeter in diode mode and they light. I also tested the strips when out of the display on the Inverter and all lit as normal!
I just confirmed the same Diode was Shorted. I had replaced with the exact type from RS electronics (V10P10), Datasheet attached.
There are 2 others on the board which are still fine. The Inverter works without it but as I do not understand how the circuit is fully working I'm not sure if it is a good idea to leave it out!!
There are 3 sets of Inductors so are they sharing the load so if it is left out are the other 2 sets running at higher current?
So any ideas as to why it has blown 2 so far!
I have annotated the pictures please have a look.
Cheers.
Cheers.
