Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when on but no screen charging happens.
VA and VS are stable and at specified volts, BUT VE voltage on X-main is above rating by 37 volts (supposed to be 94v but is 131v) and will not adjust down. Nothing on X board looks burnt or cracked. All fuses on X board are good. Pulled the other small cap and it tests within spec.
Tried removing main board to test for color patterns but still no luck, logic board flashing fast from VE being high I guess. VS and VSCan on Y main are present and correct. No componets look burnt on Y or buffer boards.
I have another logic board exact P/N from a Phillips 50" that I tried but same symptom VE high.
Am I correct in thinking that the problem is on the X-main since it generates the VE from the VS voltage? Or has the panel gone bad? Picture had been great til above happened. Thanks.
