Waterfox now supported by XP64!!
    http://www.waterfoxproject.org/
    This was a long time a-coming!!! I was updating waterfox on my win7 laptop and noticed it said XP64 in the supported OS list, I had to re-read it to make sure I read it right!!! ....and sure enough, I downloaded it and checked it on my main rig (X64 of course), and sure enough!! YAY!! This just extended the life of XP64 indefinitely for me, it was the only program I wished for the longest time was supported by X64....and now it is!
    LONG LIVE XP x64!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    Re: Waterfox now supported by XP64!!
    Coincidence! I just installed XP x64 today!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      i tried to install it on my laptop yesterday kept telling there was no hard drive.
      My Computer.
      AMD APU A4-3300 2.5ghz 1mb cache
      Motherboard GigaByte GA-A75M-S2V
      Kingston HyperX Blue DDR3 8GB (2x4GB)
      SB Audigy 2 ZS [B800] Sound Card
      500GB WD Caviar® Blue™
      1 Terabyte WD Caviar® Black™
      2 Terabyte WD Caviar® Black™
        Your laptop is probably in AHCI mode and you probably don't have an AHCI driver for your chipset.
          It's interesting keeping this in mind:
          http://www.techspot.com/news/50887-f...r-windows.html
          But thanks for the recommendation, I installed it, actually the first 64-bit browser I'm using, never started using Opera 64-bit (It's my browser of choice otherwise)
            Topcat, can you please force-enable acceleration and run these tests:
            HWACCEL
            GUI Mark 2
            Can you also post your Graphics section of "about:support"?
            To force-enable acceleration, go to about:config and change the following to true:
            1) gfx.direct2d.force-enabled (This one shouldn't do anything, as Direct2D acceleration will never be supported with any iteration of Mozilla in XP, but I'm still curious to see if there's any result)
            2) layers.acceleration.force-enabled
            3) webgl.force-enabled
            Here's what I get with Chromium (Not that I use it, I just wanted to test it):
            Chromium 25.0.1326.0 (Build 167754)
            That version of HWACCEL I posted is limited to 60fps...
            Oh, and does changing gfx.font_rendering.directwrite.enabled have any effect?
              I will when I get home. The GX745 I'm on right now probably wouldn't be the best to test with, its a pretty weak system.....but it likes waterfox.
              Team : 49813
              Join in!!
              Team Stats
                My office machine with a crappy GT9600 GPU said 18FPS. I'm wondering how you got 90FPS when it tells you that results are limited to 60FPS....hmmm
                Team : 49813
                Join in!!
                Team Stats
                  My home system said 49FPS with a GTX580. Nice framerates....but I still choose not to run a browser put out by a company that made its fortune spamming the world. I'll stick with my slow Mozilla.....
                  Team : 49813
                  Join in!!
                  Team Stats
                    For me, Firefox works best when you use:
                    Code:
                    nglayout.initialpaint.delay 0
                    and
                    Code:
                    network.http.pipelining true
                    Then general browsing may be faster than all the other browsers!
                    The default delay is pointless for today's internet.
                      Chrome is horrible Firefox all the way!
                      IF I were to have to use Chrome (and that's IF) I would use Comodo Dragon.
                        The official HWACCEL is limited to 60fps... Someone posted a downloadable version without the limit.
                          Don't upgrade to version 18.01 or you will get this error:
                          "Waterfox.exe is not a valid Win32 application"
                          https://www.google.se/search?client=...32+application
                            Yup, already found that out. Had to go back to 16.
                            Team : 49813
                            Join in!!
                            Team Stats
                              thanks. didnt know about this browser. really fast.
                                Awesome, still got an XP 64 machine running. Is Waterfox a lot faster than firefox?
                                  Just a little trick to waterfox and XP...the last installer of waterfox that works with XP is 16, after that, its all vista and up. If you want to run the latest version of Waterfox on XP, install 16 as normal. Then download the portable of the latest version.... Extract the files, backup your waterfox folder, and then copy the new files from the extracted portable into the waterfox folder. When you start it, it goes through the first-run hocus pocus....and then shazam, latest version of waterfox on XP64 (or in my case, server 2003 x64).
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                    cool!
                                    wonder why they dropped support when it runs fine anyway?
                                    sort of like my friends 2000 box that melted down when the neutral opened last week.
                                    he bought a nice quad core box i had and then found out the really old quickbooks would not install on 7 x64.went to the floppy disks folder and started install from there.
                                    it worked fine.the limitation was in the flashy installer front end only!
                                      Originally posted by kc8adu View Post
                                      cool!
                                      It needs to be recompiled with VS 2010 or earlier or change an option that's disabled by default in VS 2012 and later.
                                      With VS 2012 and later, after changing the option, recompile.
                                      Or XP will think it's corrupted! It's actually Windows rejecting it, because it thinks it's a malformed .exe and the like.
                                        only v18 did that. I'm running v26 with the little trickery above, no issues....but the installer won't run on XP.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
