LG OLED Screen protection remover
    Hi all
    I have 2 LG b8 OLED TV with problem of protection mode as i think , i realized that if i disconnect any cable from 4 ribbon cable of Panel , T-con will be in protection mode , so the the TV will not power on , i connected all panel cables and disconnect the bottom cable from main board to T-CON the TV power on with sound without any picture , but its mean main board is good, when connect all cables screen flicker white then off, relay on power supply click ,then off , its mean there is order to protect boards , how to remove this protection ,and let TV to work not perfect but 50%
    Thank You
    Re: LG OLED Screen protection remover
    might be back-lights fault
      LG OLED TVs do not have Backlights like Samsung QLED TVs.
        wont be back lights then
          Tcon ?
            Tcon ?
            I replaced T-Con from working screen, same problem
              there are posts in the forum for using a service remote OR using a computer wave file to generate the IR signal from a phone output jack to an IR sender. this is used to reset the protection is the service menu BUT if the issue is the panel, it will come back on after a number of attempts / turn on cycles.
                please in details how to do that
                  QFT, OLED is not LCD!
                  And to the TV noobs, "LED" doesn't automatically mean LCD with LED backlights, FFS!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  16 GB AData XPG Spectrix D41
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
