Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 09-27-2019, 05:11 PM   #1
ivtec
ivtec
City & State: Fall River, Mas,
My Country: USA
Line Voltage: 120-60hz
I'm a: Hobbyist Tech
Default HDMI cable fix help?
Hi guys any body ever tried to mend an HDMI cable one one side ,i have an HDMI 15 feet and one end got damaged ,i have extra 3 feet cable, is it possible with no deficiency in Q sound by cutting one side and mend it to the bad end? thanks
ivtec is offline   Reply With Quote
Old 09-27-2019, 08:00 PM   #2
Curious.George
Default Re: HDMI cable fix help?
Quote:
Isn't it easier (and more reliable) to just spend < $10 for a new cable?
Curious.George is offline   Reply With Quote
Old 09-29-2019, 10:55 AM   #3
ivtec
ivtec
My Country: USA
Quote:
Thanks mate could do that if it was easy to remove the cable through the wall, i have to open a bigger hole cause i had it closed with plaster,if i can do it as in the video and it works then i save 10 bucks and more work,if not i will replace it.
Old 09-29-2019, 11:15 AM   #4
SMDFlea
Moderator
City & State: York
My Country: UK
I'm a: Knowledge Seeker
You can repair it by soldering on a new connector or using a breakout board .
https://www.instructables.com/id/Repair-a-Hdmi-cable/
https://www.amazon.co.uk/Adafruit-HD.../dp/B0727Q5YPC
SMDFlea is offline   Reply With Quote
Old 10-01-2019, 10:40 AM   #5
ivtec
ivtec
My Country: USA
Hi guys; i have good news , HDMI project success , i was able to connect both ends of the HDMI cable and i just used tape (no solder) just twisted both ends of each wire together,it was easy because i used same type and color HDMI cable, (not sure if all HDMI cable uses same color wire skim), this is first time i cuff off an HDMI cable end ,so keep that in mind,if all HDMI cable are not same color? don't try this unless you have tools to test each end, and it will take forever,thanks to you all that gave tips for other solutions but this was the cheapest and the faster.
Old 10-02-2019, 02:33 PM   #6
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
thats great! thats one less hdmi cable in the landfill polluting the earth! lol!
ChaosLegionnaire is offline   Reply With Quote
Old 10-02-2019, 04:12 PM   #7
ivtec
ivtec
My Country: USA
Quote:
Got ya,bro
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
