Probook 440 G8 SVP Password
    Hi all , I have a prebook 400 g8 here with a supervisor password .
    Does anyone know how to get rid ? I can post dump if needed I haven't opened it up yet .
    Is this model a straight dump or require patches etc like the Lenovo ?
    Thx in advance
    Last edited by SMDFlea; 11-22-2021, 10:12 AM. Reason: Renamed with proper model 440 G8
    Re: Probook 448 G8 SVP Password
    let post your dump here
      Thanks for getting back to me , Do you know the model of the IC that contains the file ? and / or its location ?
      Thx
        Thx
        Do you know what model the laptop is, is it a 448 G8 or a prebook 400 g8
          Its a 440 G8
            i have same problem
            this machine have two bios 16mb
              440 g8 dax8qamb8d0
              hi,
              440 g8 dax8qamb8d0
              sn: 5CD106Q3NZ
              i have the same problem as Lenovo T14
              https://www.badcaps.net/forum/showth...&highlight=t14
              when I skip the network connection there is no problem.
              but when connect to a network, laptop is automatic connecting to a work account.
              I have tried another bios+ec.
              problem seems solved. but with another bios and ec i get Hp Endpoint Security Controller Problem.
              I will upload both bios and ec
                Re: 440 g8 dax8qamb8d0
                Originally posted by osman68i View Post
                hi,
                440 g8 dax8qamb8d0
                sn: 5CD106Q3NZ
                try this ... enter the bios and restore the security settings to the default values and restart the laptop ...
                  Re: Probook 440 G8 SVP Password
                  i have tried everthing,
                  can someone build a bios or ec without getting endpoint security error?
                    @osman68i
                    This laptop is business, no solution directly by EFI firmware (BIOS) will work, the solution is in EC/KBC, just reprogram it.
                      i think problem is not in kbc.
                      i have programmed good bios and ec.
                      the problem with account is solved
                      but i get hp endpoint security error.
                      i have posted good bios-ec and problem bios-ec
                      maybe someone can compare and fix it for me.
                        @osman68i
                        I was referring to Lenovo T14
                          hp probook 440 g8 password
                          Hello, how are you
                          Please help, I want to delete the password for dump
                          hp probook 440 g8 id 2Q52BAV
                          DAX8QMB28A0 REV:A
                            Re: hp probook 440 g8 password
                            Originally posted by nafienew View Post
                            Hello, how are you
                            DAX8QMB28A0 REV:A
                            You have a second chip left (it's probably on the other side of the motherboard). Find and upload it here.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              Thank you
                                Thank you
                                Only flash EC file
                                  Originally posted by hoaca388 View Post
                                  Only flash EC file
                                  Is this the file that has the password?
                                  Did you delete the password?
                                    Why not try it? Maybe luck will come to you.
                                      I tried and it looks like I'm lucky thank you champ
                                        Hello, how are you
