At first Glance: The new WD VelociRaptor
    Info on the drive.
    Okay, so it is a a 10K rpm drive and so far the benchmark results have shown that the additional 2.5K rpm has sped reading and writing up but in all honesty I would be too scared to use the thing.
    With more than six years of searching the internet and two boxes of hard drives stored in my basement I have never seen a drive that is so small yet requires such a massive heatsink (and if you narrow down the field to drives used in PC's and not proprietary systems, any kind of heatsink at all).
    Ventilation would be a must and if someone had these in a RAID configuration, well there better be at least two fans on that drive cage.
    Other than that it seems like a good drive though with it's $300+ pricetag for just 300Gb of space I could not see myself getting one any time soon.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    Re: At first Glance: The new WD VelociRaptor
    look at the specs... it only draws ~6W which is less than what most 3.5" disks need.
    2.5" disks run cooler anyway, so it's not gonna get MUCH hotter than a conventional 7.200rpm hdd with those fins I suppose.
    if there's a moderate airflow, a massive aluminium block would probably work, too.
    if the case design is crap however, even these fins won't help much. good they have a 5-year warranty.
    not that i wouldn't trust it (WD is still on my personal "good" list) but you get TWO samsung HD103UJ (1TB, 32MB cache, yeah) for the same money.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      looks like a SAS 2.5" with a sata connection instead, in a 3.5" frame
      SAS 2.5" are already with many installations in enterprise rackmount servers
      first time i saw them i thought if it is so small how can it be reliable.
        I would love to have this drive in an c2d laptop would make a really good desktop replacement.
        I hate expensive laptops with 5400rpm hdd`s only to get the runtime on the paper longer.
          yes it would be a dual purpose machine. notebook and sandwich toaster
            I also thought about my laptop! But its to tall damnit!
              Pentium, the heatsink is so big because it adapts a 2.5" drive into a 3.5" slot. It has too few fins to be able to cool a very heating drive, so the drive itself doesn't heat much or WD made a wrong heatsink. Only time can reply.
              I think high speed drives aren't really a bargain: too expensive as disk drives and not many advantages over SSDs: Raptor strong point is its reduced latency wen compared to normal hard disks, but it's still higher that flash based devices (4 ms vs typical 0.1 ms).
              Just my 2 cents.
              Zandrax
              Have an happy life.
